Script worked in 3.30 but not on 4.2
I use a script to grab the wan ip address from a pppoe interface. This script worked find in 3.30 but when I run it in 4.2 I get an error. Can anyone see what is wrong with this script?
:global wanip
:global waninterface
:global lastwanip
:local int
:foreach int in=[/ip route find dst-address=0.0.0.0/0 active=yes ] do={
:if ([:typeof [/ip route get $int routing-mark ]] != str ) do={
    :global waninterface [/ip route get $int interface]
:set wanip [:pick [/ip address get [/ip address find interface=$waninterface] address] 0 [:find [/ip address get [/ip address find interface=$waninterface] address] "/"]]
:if ([ :typeof $wanip ] = nil ) do={
       :log info ("WAN: No ip address present on " . $waninterface . ", please check.")
} else={
      :if ($wanip != $lastwanip) do={
        :log warning ("WAN ip address changed!  " . $waninterface . " changed to: " . $wanip)
        :global lastwanip $wanip
         /interface 6to4 set sixbone local-address=$wanip
         /system script run freedns ;
        :log warning ("Update Done! ")
:global lastwanip $wanip ;
It appears that in 4.2 you no longer can get the interface associated with a route:
/ip route get 0 [tabkey]
active       bgp-atomic-aggregate  bgp-local-pref  bgp-prepend  check-gateway  disabled     dynamic         mme          ospf-type  received-from  routing-mark  target-scope  value-name
bgp          bgp-communities       bgp-med         bgp-weight   comment        distance     gateway         ospf         pref-src   rip            scope         type
bgp-as-path  bgp-ext-communities   bgp-origin      blackhole    connect        dst-address  gateway-status  ospf-metric  prohibit   route-tag      static        unreachable
I don’t know if that’s a bug or intended. It’s possible that this value is only exposed in the routing-test package. Were you using routing-test on 3.30, but aren’t using it on 4.2? If so try installing that and test again.
A simple workaround for you for now on your system as is should be to hard code the interface name instead of dynamically finding the first quad-zero route that doesn’t have routing-marks on it:
:global wanip
:global lastwanip
:set wanip [:pick [/ip address get [/ip address find interface="YOUR_INTERFACE_NAME_HERE"] address] 0 [:find [/ip address get [/ip address find interface=YOUR_INTERFACE_NAME_HERE"] address] "/"]]
       :log info ("WAN: No ip address present on YOUR_INTERFACE_NAME_HERE, please check.")
} else={
        :log warning ("WAN ip address changed!  YOUR_INTERFACE_NAME_HERE changed to: " . $wanip)
But I don’t know if any other scripts you use need the waninterface global.
