Scripting after upgrade from Ver 2.9.51 to ver 3.30
Hi Folks,
I’ve just taken a new MT box into use with version 3.30. I’d be interested to know if the scripts on the old (ver2.9.51) box should work without modification.
If not, is there a doc anywhere that list the differences in the two scripting languages?
Grateful for any advice/comments.
rgds
Jim Heck
Here is the scripting manual for v3.x
http://wiki.mikrotik.com/wiki/Scripting
Hi mrz,
Thanks for the link to the new manual.
I was wondering if I should expect my old (ver 2.9) scripts to work with the new box (ver 3.30). Or will I have to make modifications to the scripts?
rgds
Jim
you will have to modify it, main difference is that you have to define variables before usage in script.
Thanks mrz! Looks like I’ll have to study the manual!
thanks and rgds, Jim
