Scripting and [] commands in PEAR2_Net_RouterOS
Using PEAR2_Net_RouterOS-1.0.0b6
The following works fine the in the Mikrotik Terminal. But I cant get it to work via the API. How would I do the following:
:foreach user in=[/ip firewall address-list find find address=10.2.2.2] do={
   /ip firewall address-list disable $user
Or
ip firewall address-list disable [/ip firewall address-list find address=10.2.2.2]
Easiest would be:
$util = new RouterOS\Util($client);
$util->setMenu('/ip firewall address-list')->disable(RouterOS\Query::where('address', '10.2.2.2'));
Although there is a bug with Util and queries with multiple matches that’s already fixed in the upcoming version… Until that version is released, if you have more than one match, you could use:
$ids = array();
$util->setMenu('/ip firewall address-list');
foreach ($util->getAll(array('.proplist' => '.id'), RouterOS\Query::where('address', '10.2.2.2')) as $item) {
    $ids[] = $item('.id');
$util->disable(implode(',', $ids));
Thank you, so much!
