We use ADSL connections at a few sites and would like to VPN using dyndns.org service. Is there a script (dns update tool?) that can do this?
I had this problem too, untill i discovered http://www.changeip.com
This works just as well and you do not need a windows machine.
Check wiki and posts by user changeip for the scripts.
Hope this helps.
Thanks for the help, but is this not the same service that dyndns.org offers?
we do the same thing as dyndns. we are even better and cheaper : )
Is it cheaper than free? The basic dyndns service is free!
yes, we offer free ones too. for custom dns it’s only $6 though instead of their $25.
How many free accounts can we create? I need 5
