I have an issue with the information stored in the virtual interfaces made by Capsman.
I choose Virtual static in order to be able to add the interfaces in the bridge vlan ports (since I have bridge filter on).
Each interface has a different tag.
The wlan interfaces transmit the correct SSIDs but when I print the details via script/api or just double click them on winbox they all have the SSID of the master interface.
In that way I cannot select them dynamically with a script to add them to the correct bridge vlan tag list.
The weird thing as I said earlier they transmit the correct SSID but prin the master’s interface SSID.
I could also pick them using the vlan-id but they also show 1 even if they are for real at a different vlanID
Does anyone have a solution or is it a bug that has to be fixed by mikrotik?
