Scripts cannot run with permission denied V7.13.4
Hello all,
After upgrading to v7.13 from v7.11 the script from dynu is not running with the following error: Couldn’t start task: cannot open file: permission denied
The same script was running the last 5 years without any issue, owner of script is admin with full permissions
Thank you
Simos
  1. Read changelog before update. And not only the one for the 7.13, but all changelogs between 7.11 and 7.13.
  2. If work, why upgrade?
  3. Add “ftp” policy.
We have the similar problem. The difference is that we have an external script which uploads reset.auto.rsc file. We upload file from a user with group full. This file contains:
/system backup save encryption=aes-sha256 password=XXXXXX name=rollback.backup
/system reset-configuration skip-backup=yes no-defaults=yes keep-users=yes run-after-reset=prebackup.rsc
And each line of this script fail with “script error: not enough permissions (9)” error. Our configuration synchronizer is broken. Is there a solution for our issue?
Appreciate for your help.
I run the dynu script and do not have ftp policy checked and my script runs without issue.
@rextended ... so why are you stateing point # 3) ?
I have not seen the OP's script .... my dynu script is below:
/system script add dont-require-permissions=no name=Dynu owner=aaaa policy=read,write,policy,test source=":local ddnsuser "zzzzz"
\n:local ddnspass "^XxXxXxXxXxXXXXz"
\n:local ddnshost "blaNNN.myddns.rocks"
\n
\n:local currentIP ([/tool fetch url="> https://api.ipify.org> " as-value output=user]->"data")
\n:local dnsIP [:resolve $ddnshost]
\n:if ($currentIP != $dnsIP) do={
\n :local update "> https://api.dynu.com/nic/update?username=$ddnsuser&password=$ddnspass&hostname=$ddnshost&myip=$currentIP> "
\n /tool fetch url=$update keep-result=no
\n :log info "DYNU $ddnshost updated: old IP was $dnsIP and new IP is $currentIP"
\n}
\n"
What I did when facing similar issues was to give the script all permissions (policies) and - when it worked - starting removing them one by one until the script stopped working to find which ones were needed.
I guess it can be defined “permissions brute-forcing” :open_mouth:
In my case it was "/tool traffic-generator inject " command requiring the “sniff” one:
http://forum.mikrotik.com/t/my-gratuitous-arp-script/158056/1
Hello all,
FTP is needed to version 7.13 for dynu script to work
Thank you all for your input
Please Suggest me any one how to fix netwatch host script
scrip some text by mask
@mozerd
@sims
  1. Do not hijack other people topic.
  2. Read changelog before update. And not only the one for the , but all changelogs between and .
  3. If work, why upgrade?
  4. Add “ftp” policy on the script that netwatch call.
Brother
can please more explain , where to add ftp policy , i'm too beginner plz help
thanks.....
Look at the screenshot on the first post:
http://forum.mikrotik.com/t/scripts-cannot-run-with-permission-denied-v7-13-4/173794/1
Get to that window in Winbox selecting the script.
Tick the box labeled “ftp” next to “Policy:”
Apply.
OK.
do we have any solution how to make NETWATCH with script work?
Hi all,
I got it worked.. Please read this post here http://forum.mikrotik.com/t/netwatch-with-fetch-stopped-working-after-7-13/172865/21
The thing is something changed after the upgrade and Netwatch didn’t have the permissions anymore when calling fetch tool. My solution was to add “output=none” to my script that has a generic Discord webhook.
I hope this helps you too.
