I hit a wierd problem that i think is a bug in 3.0rc10
I made a script that uses global variables (by another script)
When i run the script manually everything works as expected, but when i schedule it it didnt work
Too me a while to trace where the problem is but it appears that when scheduled, scripts have no access to already defined global variables.
for example if i define :global MYTEST 200 in one script or in the console and create script as follows:
:global MYTEST
:log info ($MYTEST)
When runing the script manually everything is working
byt when runing it with scheduler i get nothing
Is this a bug or am i doing something wrong?
Kind regards
