scripts work with some devices NOT other
Dear All
I was looking for script to auto block any client to connect to my hotspot after 3 wrong time writ username or password and at the seam time i try to search on this forum and finally i fond this
http://forum.mikrotik.com/t/solved-bruteforce-http-chap-login-prevention/104911/1
its great script and its work with Mikrotik RB4011iGS+RM BUT i notes that its NOT working on RB5009UG+S+IN
i compere export.rsc for both devices and there is some deferent (see Pic)
the RB5009UG+S+IN disable the firewall filter by it self
any help please
best regards
I don’t think it has something to do with the Hardware, but with Software…
Which RouterOS are your running on your RB4011?
Still the ROS6 ?
both of them RouterOS version 7.1rc6
Any update or comment please
Thanks for all
