This is probably super basic, I went through the documentation, I spent hours on this and I simply dont get it.
I have two IPsec tunnels, one is coming from AWS to my firewall, and the second one is from my firewall to the customer.
I need to deliver the traffic from AWS to the customer → AWS is sending the traffic to the customer IP.
I want to NAT the source IP address from AWS.
Src-nat and dst-nat are locate in different chains and are executed at different times, dst-nat before routing & src-nat after routing. One can’t interfere with the other.
List your full firewall config if you need further assistance (/export hide-sensitive)
I found a config that works for my scenario but I get the feeling I could do this better.
I got the Mikrotik tunneling with IPsec from my AWS to an external endpoint that I dont control.
What I want is traffic from AWS 10.93.0.0/22 to the endpoint 10.15.1.1, and the deliverty must appear from 10.2.200.8/29
My idea was a NAT rule that will grab this traffic and change the source IP address, simply as that.
But since I could not come with a the rule that would do the trick, I did the following:
I send the traffic from AWS to 10.1.200.2 (which is my Mikrotik)
I dstNAT this traffic to the destination I want 10.15.1.1
0 chain=dstnat action=dst-nat to-addresses=10.15.1.1 src-address=10.93.0.0/22 dst-address=10.1.200.2 log=yes log-prefix=“”
then I do the scrnat
1 chain=srcnat action=src-nat to-addresses=10.2.200.8/29 src-address=10.93.0.0/22 dst-address=10.15.1.1 log=yes log-prefix=“”
This is working, but I dont like it, since I could send the traffic from AWS to the to the right destination in the first time. But when I tried that, my accept dstNAT rule was hit and it never entered the scrNAT one.
How could I have done this better, any idea?
