Scroll in Winbox
I have my machine up to day, with the 2.9.8 version.
My winbox loader does not have the down´s scroll.
Many thanks
can you make a screenshot of it?
It´s true that it not exit in previous version.
I don´t known about paste you a screen, because a can´t post it in a web.
Tell me another way to send you the screenshot
email to support@mikrotik.com
I’ve run into this many times as well - if you are talking about the scroll on the log window. If you close the log window and then reopen it then its there again. I think upon initial load the scroller does not initialize properly.
Sam
The problem is with the down scroll, because i can´t see the complete width of the log window.
Because the window have a lot of fields, i can’t see the right end.
I don’t known if you understand me.
Can you drag the window to the left using the title bar; and then size the window smaller? I have been able to do that on mine if the screen resolution isn’t high enough to see all of it.
Sam
Or i don´t understand you, or you to me.
My unique problem, is that i haven’t a hoizontal bar scroll.
I can re-size and move the principal window, and the secondary window, but i haven´t a horizontal bar to see the right-end fields althoug i do the secondary window smaller o bigger.
But best regards and many thanks.
I noted this too, I don’t have horizontal scroll bars in any window… I don’t have any parameter to comper because I started to use Mikrotik on 2.9…
are you using a 800x600 resolution? then we are aware of this problem, immediate fix is to use higher resolutions of display
