Scrpit / Command Help! WGET!
Hi Everyone.
So i have 2 450g’s v3.25
I need help with a really cool script!
Can we get a script/command made than can to the following:
Every 5 min, do a WGET from a site, and if it doesnt exceed a threshold of X mbps, email an address with a message? (then automatically delete the file after)
I am very open to better ways to do this!
The idea is, to detect if our bonded dsl modem is having trouble. From time to time, which is almost every few days since we have a bunch of sites, the DSL modem will have trouble with a loop, or bonding, or something and need either a reboot or the ISP to cycle something. The modem will still work and ping back fine, but throughput is really the only way to know. And we cant be checking 10 routers every day.
Any idea of how tasking this is on a router? Should we put in a micosd card to the 450g? or do you think it has enough room for the download safely? (say its 5-10Mb)
Let me know Smile
Have a search on the wiki, there is a bunch of scrips, will probably not do exactly what you want, but should give a an idea how to modify it.
