Scrpit to enable or disable interface list
Hello guys I’m new in this networking world.
I can run scheduler.
But I don’t know how to write a script to enable or disable interface list.
Please help
/interface list member disable [find where list=“your-list”]
/interface list member enable [find where list=“your-list”]
The interface list can’t be disabled,
you can only disable or enable all specific interface list members at same time, like @jonah1810 has wrote.
Thanks mate that works in command line yes,
How can i put that command in script..
Currently i’m doing it manually which is tough to keep up with :frowning:
How can i run those terminal commands by a script ?
Why you change the command?
On your screenshot you are removed “member” and added the " at start and at the end of the command.
must be writed as-is:
/interface list member disable [find where list="listd"]
Thank a lot :slight_smile: it worked :slight_smile: :slight_smile:
