We have 2 Dell 1550 server I would like to use, is there any other way around this? There is a IDE interface that the CD is connected to but all the drive bays are SCSI back plane and there in no room internally for a drive
Cheers tully the only problem is I don’t have any of the internal power connectors the back plane supply’s the power for everything. I surpose I could connect one into the PSU wiring.
Is there no chance of getting RouterOS on to SCSI?
router doesn’t use the hard drive so often, so you don’t need that speed of the SCSI drive. even if you’re caching. apart from specific hardware devices who don’t have IDE, is there any specific reason you think SCSI is important?
My main reason is specific hardware devices. I tend to try to put old server units to use as other devices to make as much use of them as possible. I have a pair of 1u Dell 1550 which (bar not having IDE) would make an excelent pair of ROS boxes.
There is no standard on SCSI HDD controllers. Of course, one could make an autodetection, and that box would start up about a munute or two longer (modprobe spends about 10-20 sec. on one controller type, if I recall correctly)… But this autodetection is not really a reliable one - it is sometimes possible to autodetect a SCSI controller incorreclty…
There would be a whole new would of uncommon problems related to SCSI. Starting just with unapplied or mixed up termination rezistors as a quick example of such.
So, there is no chance to see SCSI HDD support at least in this year. Of course it is rediculous to tell “we would not have it for the time being, point” as the would we live in is too unpredictable But not in the near future…
And BTW, if these Dell boxes had a PCI slot you could put a PCI ATA controller inside.
I think the only benefit of SCSI is speed and load balancing accross multiple drives. So that only applies to caching. Virtually all heavy use web caches use SCSI and for good reason. I guess its a matter of if you want a heavy use web cache do not use Mikrotik. I don’t think that is the market Mikrotik is going after anyway. There routers work great though for about everything else. Oh, I guess they won’t equally load balance T1’s either. Speaking of that what T3 cards do they support and do they support fractional T3’s?
Instead of SCSI how about support for 2 IDE drives on seperate channels for the web cache? Or how many drives does SATA support? Perhaps the web proxy could be spread accross 1 - 4 SATA drives?
It supports a CF card to boot from and a separate IDE drive for the cache. My proxy drive is a 40gb 7200rpm WD with 8mb on-board cache on a Ultra100 IDE interface. Someone else will have to say whether or not the IDE cache drive can be on a SATA interface, but it should work.
