sd card missing
My RB1100aHx2 running v5.20, my micro SD card is missing if i restore the configure.
it does not show in SYSTEM>STORE>DISKS
It only appear except i unplug the power and restart.
what’s wrong ?? I think i got similar case as
http://forum.mikrotik.com/t/rb450g-ros-5-14-microsd-strange-problem/54495/1
But as told in thread it seem fix, however it seem happen on me with v5.20
Any help ?? thx
help…
Supposedly class 2 sd cards are recommended.
I have tried a Class 2 Transend 2 GB SD Card in one of our RB1100AHx2 running RoS 5.20 and it does not survive a soft reboot.
Only a power down resolves the problem.
YES, I also need power down to resolve the problem.
Also if i restore the configure, the SD card disappear :confused:
Is it only happen on RB1100ahx2 ?
or Any rumor this will fix later ?
thx
I have seen it on RB450G and RB493G as well.
same here with RB450G (5.19) using 2gb sd proxy working stops and after restart SD icon gone sometimes both SD & System drive but I can see files in files… but in store disk nothing showing.
it happens to me too, board 433ah with 2gb micro sd. After soft reboot, there are no disks in system stores…
Also, during operations, proxy cache contents is lost.
Hard reboot and it goes again ?!
Br, Petar
Please tell us team its a SD compability issue or something wrong with ROS…???
