SDN VXLAN Tunnel between Mikrotik & Open vSwitch
Hi Guys,
Does anyone know how to set up a VXLAN tunnel between Mikrotik and Open vSwitch (OVS)?
I have successfully set up VXLAN between two Mikrotik CCR1009-7G-1C-1S+.
Also VXLAN between multiple OVS works well.
But I can’t get the connection between Mikrotik and OVS working.
Is this possible at all and if so,
can someone provide an example config?
Thanks a lot
hakke
Hi, have you found a solution for this? I am trying to do the same.
