I have several AP’s but i need to choose the best of them… Someone have a script to do something similar to this…
Best regards
Best regards
Best in what way. Largest? Most powerfull? Fewest clients connected?
Client will normally select the most powerfull access point by it self.
I’m trying to develop a script to check all that kind of values… and choose the AP !! If you can help me with some scripts would be great !
Best regards
What your asking is very vague.
What are the client device types?
What values do you want to compare, and what weight are each given? (i.e. how do you define the ‘best’ AP)
For values that aren’t detectable by an unconnected client, how do you intend to transmit those values to them?
There’s a lot of level of integration you are asking for here - some of it possible but very finicky and unlikely to give much performance gain - what is the problem you are trying to solve?
