Search function won't work Dude 3.3
Before the update we were able to search just fine but it crashed when no result were found. Now it don’t crash but it never show result, only exception to that is if you search for what is right under the selected element.
I looked evrywhere and I’m out of idea.
Looks like the find function is only finding items on the current map. It looks like it will not find anything from the devices panel.
So to find stuff you have to go to the map you know it is on then use find…
I tested the search function in 3.4 and it seems fixed. I only checked it briefly so ymmv.
Yes your right it work now thanks.
