Searching multidimensional arrays
Because dynamic interfaces can come and go, I have a need to make a snapshot of what interfaces exist at a given point in time, and then search through the snapshot rather than do a real-time search.
For example, instead of…
/interface find name~"ether"
…I want to first capture & store the existing interfaces to an array of an array…
:local $interfaces [/interface print detail as-value]
…and then search through that multidimensional array the same way I would through the active interfaces array (e.g. by being able to reference particular array keys), like so:
:find $interfaces name~"ether"
The hope is that I would get back a list of IDs (perhaps representing positions within the array) of matches. But of course :find doesn’t seemingly work like that.
I can of course search through the entire contents of the array for a regex match…
:put ($interfaces~"ether")
true
…but that’s not exactly helpful, now is it?
Really hoping this is possible to do without iterating over each array member, which is very much Not Quick. Thanks for any leads.
I do not think there is an easy way, you can do something like this:
:foreach i in=$interfaces do={ :if ($i->"name" ~ "ether") do={
   do your thing here
Something like this is ok?
    :local from "ether2"
    :local what "mtu"
    :local snapshot [:toarray ""]
    :set ($snapshot->"date") [/system clock get date]
    :set ($snapshot->"time") [/system clock get time]
    /interface
    :foreach if in=[find] do={
        :set (($snapshot)->[get $if name]) [get $if]
    :put "On snapshot maded $($snapshot->"date") $($snapshot->"time")"
    :if ([:typeof (($snapshot)->$from)] != "nothing") do={
            :put "$from has $what set to $((($snapshot)->$from)->$what)"
        } else={
        :put "value $what for $from not found"
    } else={
        :put "$from not found"
Where the snapshot is maded have different results for example /interface and /interface ethernet:
[rex@tended] /interface> get ether2
actual-mtu disabled fp-rx-packet l2mtu link-downs mtu rx-byte rx-packet tx-drop tx-queue-drop
comment dynamic fp-tx-byte last-link-down-time mac-address name rx-drop slave tx-error type
default-name fp-rx-byte fp-tx-packet last-link-up-time max-l2mtu running rx-error tx-byte tx-packet value-name
[rex@tended] /interface ethernet> get ether2
advertise combo-mode disabled fec-mode loop-protect-send-interval name rx-…
arp comment driver-rx-byte full-duplex loop-protect-status not-learned slave
arp-timeout current-learned driver-rx-packet l2mtu mac-address orig-mac-address speed
auto-negotiation custom-drop-packet driver-tx-byte loop-protect mdix-enable policy-drop-packet switch
bandwidth default-name driver-tx-packet loop-protect-disable-time mtu running tx-…
