I’ve been looking at the “/ ip firewall connection” list recently and trying to search it based on src-address and dst-address.
The problem is that it seems to require that you specify a port number, so that:
:put [find src-address=192.168.0.112]
returns nothing.
Instead I’d have to print the whole list and specify a port number, for example:
:put [find src-address=192.168.0.112:4510]
which kind of defeats the purpose.
Is there some way of giving a wildcard port number, to get a list of all connections from a specific IP address?
Thanks,
Kevin
mrz
2
I don’t think that there are some kind of wildcards, but you can do this with simple script:
:foreach i in=[/ip firewall connection find ] do={
:if ( [:find [/ip firewall connection get $i src-address] 192.168.0.112 ] >= 0 ) do={
:put ( [/ip firewall connection get $i src-address] . " " . [/ip firewall connection get $i dst-address] );
Thanks, I can modify that to do what I want to do.
But isn’t it a bit ugly that way? It would be much nicer if the ports were separated from the IPs, for example src-port and dst-port.
Oh well, can’t have everything and at least your solution works and is available now.
Thanks again,
Kevin
