I am setting up a new hap ax3. My second bridge (Bridge22) can't access the internet (it has TVC-Guest wifi networks connected to it). The TVC-Guest clients get an IP address via DHCP - so that's working fine - but no access to the internet. I have setup this in a similar fashion before - but not sure why it's not working this time. The other networks aren't fully setup yet (until I figure this issue out). Thanks for any help!!!
Config:
may/20/2023 21:21:08 by RouterOS 7.9
software id = 5HP3-MTXY
model = C53UiG+5HPaxD2HPaxD
serial number = XXXXXXXXXXXX
add name="Guest-Bridge(22)"
add admin-mac=48:A9:8A:48:64:B6 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=
yes ft-mobility-domain=0x1234 ft-over-ds=yes name="TVC-Guest(22)"
yes ft-mobility-domain=0x1234 ft-over-ds=yes name=MikroTik
yes ft-mobility-domain=0x1234 ft-over-ds=yes name=TVC-IoT
/interface wifiwave2 configuration
add datapath.bridge="Guest-Bridge(22)" disabled=no interworking.internet=no
mode=ap name="TVC-Guest(22)" security="TVC-Guest(22)" ssid=TVC-Guest
add disabled=no mode=ap name=MikroTik security=MikroTik ssid=MikroTik
add country="United States" disabled=no mode=ap name=TVC-IoT security=TVC-IoT
security.ft=yes .ft-mobility-domain=0x1234 .ft-over-ds=yes ssid=TVC-IoT
add country="United States" disabled=no name="TVC-IoT(2.4GHz)-Only" security=
TVC-IoT security.ft=yes .ft-mobility-domain=0x1234 .ft-over-ds=yes ssid=
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20/40mhz configuration=MikroTik configuration.mode=ap
disabled=no name="MikroTikWiFi(2.4GHz)" security.authentication-types=
wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=
10min-cac .width=20/40/80mhz configuration=MikroTik configuration.mode=ap
disabled=no name="MikrotikWiFi(5GHz)" security.authentication-types=
wpa2-psk,wpa3-psk
add configuration="TVC-Guest(22)" configuration.mode=ap disabled=no
mac-address=4A:A9:8A:48:64:BB master-interface="MikroTikWiFi(2.4GHz)"
name="TVC-Guest(2.4GHz)"
mac-address=4A:A9:8A:48:64:BA master-interface="MikrotikWiFi(5GHz)" name=
"TVC-Guest(5Ghz)"
add configuration="TVC-IoT(2.4GHz)-Only" configuration.mode=ap disabled=no
mac-address=4A:A9:8A:48:64:BE master-interface="MikroTikWiFi(2.4GHz)"
name="TVC-IoT(2.4GHZ)-Only"
add configuration=TVC-IoT configuration.mode=ap disabled=no mac-address=
4A:A9:8A:48:64:BD master-interface="MikroTikWiFi(2.4GHz)" name=
"TVC-IoT(2.4GHz)"
/ip dhcp-server option sets
add name=DHCP-Guest
add name=Guest-DHCP ranges=192.168.22.2-192.168.22.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=Guest-DHCP interface="Guest-Bridge(22)" name=Guest-DHCP
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface="MikrotikWiFi(5GHz)"
add bridge=bridge comment=defconf interface="MikroTikWiFi(2.4GHz)"
add bridge="Guest-Bridge(22)" interface="TVC-Guest(2.4GHz)"
add bridge="Guest-Bridge(22)" interface="TVC-Guest(5Ghz)"
add address=192.168.88.1/24 comment=Mikrotik interface=bridge network=
192.168.88.0
add address=192.168.22.1/24 comment=TVC-Guest interface="Guest-Bridge(22)"
network=192.168.22.0
/ip dhcp-client
add address=192.168.22.0/24 comment=DCHP-Guest dns-server=192.168.88.1
gateway=192.168.22.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Los_Angeles
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
