I got my mikrotik (set on static address nad working fine) in my home
but my ISP got second mikrotik on my roof and I dont have access to it
problem is I cant reach my mikrotik by WINBOX from outside (internet)
http and https from outside working fine, but I need do it by WINBOX
every attempt to connect to default port … give me error wrong user name
AND this is allright because I trie log into ISP router
Obviously I was change port to example 8292 at winbox service and make hole in firewall on that port
no effect still CANT connect
I got several services inside my LAN like apache and smtp and its working fine from outside
but I CANT connect to my mikrotik via WINBOX
My ISP asure me every port is redirected to me
thanks for any clue
If you have already check all you said.
Maybe you are trying to enter in your mikrotik’s ISP , it happens to me a lot in the past. Did you check your mikrotik logs? if there is not log my theory is true.
Thank You for answer
if Im not change port to Winbox
I get error about wrong username or password and that is a proof … I get to ISP mikrotik
I can open my website (80)
I can sent emails (25)
similiar rule I put on port 8292
and still CANT connect via Winbox
there is no mistake by me side … I think
I will contact with my ISP … will see what they got to say about that
PS. Logs are clear . that means no sign about connection on my mikrotik
Ok.
Can you give more information about your firewall?
/ip firewall filter export
/ip firewall nat export
/ip firewall mangle export
