Second LAN network on RB951G-2HND
I have following network up and running without any problems.
However, I would like to add a second LAN with it's own IP address and DHCP server. I scrambled through the forum and couldn't find
the exact information I would understand to implement on my router.
Someone please inform me about what is required to implement a second LAN to separate office PC's traffic from the WiFi Unifi Lan.
Here's the existing setup - ROS V6.7
ISP-Internet
RB 951G
Ether Port 1: WAN 199.9.60.xxx
Ether Port 2: LAN - UniFi WiFi - 192.168.0.x
Ether Port 3, 4, 5 are switched of Master Port 3.
add l2mtu=1598 name=bridge1
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=
"LAN - All ports are switched off Ether2"
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
/interface wireless
set [ find default-name=wlan1 ] ht-rxchains=0 ht-txchains=0 l2mtu=2290 ssid=
MikroTik
/ip neighbor discovery
set ether1 comment=WAN
set ether2 comment="LAN - All ports are switched off Ether2"
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp_pool1 ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp_pool1 disabled=no interface=ether2 name=dhcp1
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge1 interface=wlan1
add address=192.168.0.1/24 comment="LAN IP Subnet" interface=ether2 network=
192.168.0.0
add address=199.9.60.xxx/24 interface=ether1 network=199.9.60.0
add address=192.168.0.0/24 dns-server=192.168.0.1,4.2.2.2 gateway=192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall address-list
add address=192.168.0.0/24 list=OurLocalLAN
add chain=input comment="Allow access to the router from the LAN using address
list - PROTECTING ROUTER" src-address-list=OurLocalLAN
add action=drop chain=forward comment="Drop invalid connections"
connection-state=invalid
add chain=forward comment="Allow Connections from LAN" connection-state=new
in-interface=bridge1
add chain=forward comment="Allow Established Connection from LAN"
connection-state=established
add chain=forward comment="Allow Related Connection" connection-state=related
"Drop all other traffic through the router"
add chain=input comment="Allow established connection to the router"
add chain=input comment="Allow related connection to the router"
add action=drop chain=input comment=
"Drop All Other Traffic to Router - PROTECTING ROUTER"
add action=masquerade chain=srcnat comment="PAT outside" dst-address=
0.0.0.0/0 out-interface=ether1 src-address=192.168.0.0/24
add comment="default route" distance=1 gateway=199.9.60.1
/ip service
set api disabled=yes
/system clock
set time-zone-name=America/Chicago
/system identity
set name=RB951ui
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes mode=unicast primary-ntp=63.44.154.34 secondary-ntp=
63.240.161.99
Choose a free ethernet port.
Give the ethernet port a IP-address:
http://www.wirelessinfo.be/index.php/mikrotik/pages/ip
Configure DHCP server on it
http://www.wirelessinfo.be/index.php/mikrotik/pages/dhcp
Nat the port with the wan
http://www.wirelessinfo.be/index.php/mikrotik/pages/nat
Are you trying to have multiple wireless networks?..
What you need to do then is add a VLAN to pass to the Unifis… then just treat the VLAN as a new network.
reply to @ plisken
I followed your instructions (pictures only, I can’t read the language) from the links and got the best I could do. Please see the config below and let me know what I did wrong.
I couldn’t get IP when I had port 5 independent and assigned DHCP to the port.
/interface wireless
“LAN - All ports are switched off Ether2”
set ether2 comment=“LAN - All ports are switched off Ether2”
/ip ipsec proposal
add name=dhcp_pool2 ranges=192.168.0.100-192.168.0.254
add name=dhcp_pool1 ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp_pool2 disabled=no interface=bridge1 name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp2 relay=
192.168.1.0
add address=192.168.0.1/24 comment=“LAN IP Subnet” interface=ether2 network=
192.168.0.0
add address=192.168.1.0/24 interface=ether5 network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.0,4.2.2.2 gateway=192.168.1.0
add chain=input comment=“Allow access to the router from the LAN using addres
list - PROTECTING ROUTER” src-address-list=OurLocalLAN
add action=drop chain=forward comment=“Drop invlaid cnnections”
add chain=forward comment=“Allow Connections from LAN” connection-state=new
add chain=forward comment=“Allow Established Connection from LAN”
add chain=forward comment=“Allow Related Connection” connection-state=related
“Drop all other traffice throught the router”
add chain=input comment=“Allow established connection to the router”
add chain=input comment=“Allow related connection to the router”
“Drop All Other Traffice to Router - PROTECTING ROUTER”
add action=masquerade chain=srcnat comment=“PAT outside” dst-address=
0.0.0.0/0 out-interface=ether5 src-address=192.168.1.0/24
add comment=“default route” distance=1 gateway=199.9.60.1
/ip service
/system clock
/system identity
set name=RB951g
/system leds
/system ntp client
63.240.161.99
reply to @ efaden
No, I am not trying to have multiple wifi. I am not even using the Wireless interface on RB951. The UniFi AP I have are being
used for guest wifi only.
I see that ether 3,4,5 is bridged.
Remove an interface from the bridge, for example ether5 and add than an IP address to this interface. en configure the DHCP server.
This is the reason that it fails
Ether5 becomes your new network
The screenshots that I made to my website will help you without the text to configure the routerboard.
Goodluck
Hello!
I did as you mentioned using the screen shot. However, I am not sure if it’s done correctly.
I have doubt about the NAT rules on Port 5 and I also, created second bridge.
Please let me know…
Sandip
add name=bridge2
/interface wireless
“LAN - ports 3,4 are switched off Ether2”
set ether2 comment=“LAN - ports 3,4 are switched off Ether2”
/ip ipsec proposal
add name=dhcp_pool3 ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp_pool3 disabled=no interface=bridge2 name=dhcp2
add bridge=bridge2 interface=ether5
192.168.0.0
add address=199.9.xx.xxx/24 interface=ether1 network=199.9.60.0
add address=192.168.1.1/24 interface=ether5 network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.1,4.2.2.2 gateway=192.168.1.1
“Drop all other traffic through the router”
“Drop All Other Traffic to Router - PROTECTING ROUTER”
add action=masquerade chain=srcnat comment=PORT-5_NETWORK dst-address=
0.0.0.0/0 out-interface=ether1 src-address=192.168.1.0/24
/ip service
/system clock
/system identity
set name=RB951ui
/system leds
/system ntp client
63.240.161.99
If you connect with port 5 can you use internet?
I am able to get the 1.xxx ip however, the internet is not working.
I ping yahoo.com from the router’s terminal and it responses.
I am not sure if my NAT rule is correct for Port 5.
Sandip
Take a screenshot from your nat settings pleace
I look than of it is OK
Please see the attached file.
sp9239-mk951g-2hnd.pdf (745 KB)
Nat settings see printscreens that i made.
Src Address= 192.168.1.0/24
Out interface is your WAN interface by action select masquerade
Try this
I verified what you mentioned. Still not luck.
Later this weekend I am may remove all configuration and start from scratch.
I will need some time.
I will update you on this.
Sandip
Problem Resovled.
Under the Firewall Rules (NAT)
  • I created a new rule for NAT to allow LAN traffic from Bridge 2, which is on private LAN on Port 5.
Hope I did this properly…
Thank You! to “plisken” as well for helping me along the way.
Great
You re welcome
You also should configure the secondary ip to bridge2 instead of ether5.
@ Rudios
I will look into on configuring your recommendation.
Any idea on where this should be done?
