Second router as ppoee client for security
Hi all. I have a main router ax3 and I have setup an IPsec VPN tunnel with nordvpn in a vlan and works fine. Also I have a second router and I’m thinking to create a ppoee server in ax3 and connect the second router as ppoee client and setup my IPsec tunnel there.just for security reason is better or not to bother at all. Thanks guys
Not sure if there is any real gain by doing that. If you dont trust the VPN, there is nothing to be gained by putting the tunnel behind another router.
You have firewall rules on the local MT router for most other things.
Better security would not to use nordvpn LOL. Set up a CHR in a VPS and have your own VPN, wireguard to VPS.
Have you any VPS to suggest; also will I need a licensed for chr to pay; and I don’t know how much a Vps will cost me
CHR is a onetime lifetime cost.
Try VULTR hosters they are very cheap for a 1 gig connection
shared CPU Cloud computing 1 vCPU - $5 a month using older generation devices.
More like 6 or 7$ for newer amd and intel devices.
https://www.vultr.com/features/datacenter-locations/
https://help.mikrotik.com/docs/display/ROS/CHR+Vultr+installation
Thank you very much for your help,I will look it out!!
https://www.vultr.com/pricing/#cloud-compute/
$6 gets you a newer server and I believe another $1.20 or so gets you a backup Service.
