second router with discovery first routers pc
Hi.
i try to set up a second router (mikrotikRB941-2nd ) with hotspot.
on 1 router i have more pc with the IP range 192.168.1.2-192.168.1.255
on second router WAN ( eth1)
In an eth and first Wlan 192.168.1.100-192168.1.150
hotspot 10.5.50.1/24 …
its all working but… i cant see the pc on the first router.
could somebody help me please :slight_smile:
thx
you cannot see the PC on the 1st router because your WLAN .
WLAN is set to such subnet, which create a routing entry onthe 2nd router, which will tell all traffci heading to 192.168.1.0/24 to go to the wlan interface, where the PC does not exist
change the WLAM to a different subnet.
