Hi, I’ve got a /29 assigned to me by the ISP. The ISP put their own router in place so the WAN port (ether1) is connected directly to it, with ether2 as the LAN.
Let’s say the public IP network is: 1.1.1.96/29. The ISP’s public gateway is 1.1.1.102 and works just fine.
I’ve set the Mikrotik’s WAN IP to be 1.1.1.97, and the LAN IP for the Mikrotik to be 192.168.1.1. I’ve set up NAT for the local machines.
Now - I also want to connect a server to one of the Mikrotik’s ethernet ports, and use a public IP directly on that server.
I’m pretty sure that I should be able to just set that server’s IP to 1.1.1.98 or .99, and set its default router to 1.1.1.97, but it doesn’t seem like the Mikrotik routes the traffic at all. As far as I understand, it doesn’t even need extra routing for this to be possible ?
It seems like such a silly simple problem, so I would appreciate any help clearing up my misconception.
