Second wireless interface not handing DHCP addy
I have 2 wireless NIC's installed in my routerboard. The wlan1 NIC is operating properly allowing clients to connect
and they receive a valid IP address from the DHCP server. The other wireless interface, wlang, allows connections
but does not hand out an IP address. My config looks right though. Any suggesstions??
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 GUR DHCP ether2 dhcp_pool1 3d
1 WLAN DHCP wirebridge dhcp_pool1 3d
2 wlang wlangbridge dhcp_pool1 3d
[delmar@gw1.delmar] /ip pool> print
NAME RANGES
0 dhcp_pool1 172.16.31.6-172.16.31.30
[delmar@gw1.delmar] /interface wireless> print
0 name="wlan1" mtu=1500 mac-address=00:0C:42:61:38:49 arp=enabled interface-type=Atheros 11N mode=ap-bridge ssid="GUR"
frequency=5180 band=5ghz scan-list=default wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
1 name="wlang" mtu=1500 mac-address=00:80:48:51:F5:4F arp=enabled interface-type=Atheros AR5212 mode=ap-bridge
ssid="GURg" frequency=2412 band=2.4ghz-b/g scan-list=default antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=gprofile compression=no
Any help would be much appreciated.
It looks as though it is receiving transmissions but not sending transmissions. Interesting, eh?
I can’t seem to figure this one out. Why would I only get one way traffic? The interface refuses to transmit out…
Looks like you have three dhcp servers on three interfaces using the same ip pool. Can you post “/ip address”?
ADDRESS NETWORK BROADCAST INTERFACE
0 172.16.31.1/27 172.16.31.0 172.16.31.31 ether2
1 172.16.31.2/27 172.16.31.0 172.16.31.31 ether3
2 D 216.180.136.82/32 216.180.136.254 0.0.0.0 PPPoE
No duplicate subnets here. Change the ip/subnet on ether3 to 172.16.32.1/27 (or something like that). Then set up a dhcp server on it using that subnet.
Or remove the ip assignments on ether2 and ether3, then put both interfaces in a bridge. Assign 172.16.31.1/27, and the dhcp server, to the bridge.
