I’m not much of an expert on RouterOS but had quite a good system setup. I basically have 2 ISPs. I used the mangle rules in the firewall to mark certain traffic and then in the routes table I would send specially marked traffic out the secondary ISP interface.
Now for some reason when I have the primary interface active I cannot even ping the secondary NIC from an external location.
Anyone have any ideas? Perhaps someone is kind enough to log in and take a look
Most probably mikrotik answers from the first ISP to your pings. You have to creature rules that when a new connection enters a wan interface, it will use the same interface to reply. This works for me for multiple wan interfaces as far as accessing mikrotik from all interfaces.
Thank you very much for your suggestion however it does not seem to work
Its funny in that it was working perfectly fine but now all of sudden it doesn’t seem to work, I have checked all the obvious things but I haven’t changed anything.
No, i do not use it. I would be happy to answer here if I know. I warn you though, my knowledge on mikrotik (and networks in general) is extremely limited
