Sector channel frequency seperation + Polarity
On 5.8 what is the recommended minimum channel frequency seperation and on a four sectors AP, Do i need to change polarites between the sectors ?
“On 5.8 what is the recommended minimum channel frequency seperation”
Depends of channel bandwidth… if this is 20 MHz You need to set a distance of 20 MHz from the channels (ex. 5500-5520-5540-5560)
“and on a four sectors AP, Do i need to change polarites between the sectors ?”
No. Not install the antennas too much near (about 1 mt between antennas it’s good, You can made a X support).
Bye.
Paolo
( “and on a four sectors AP, Do i need to change polarites between the sectors ?”
Bye.
Paolo )
X support that is a idea thanks, But till then i am thinking that to get a 1 mt between sectors, then i might mount the sectors diagonally to get that physical seperation, Ok a drop in height but i would rather avoid if possible any interference caused by sector proximity-
n21roadie
