Sector writes at ssh disconnection
I tried some command, e.g. ssh mikrotik ‘/system export’ and saw Rector writes increased by 2 in Resources.
Why?
I completely disabled any logging to disk, so very confused how to disable this writes, because very often use remote commands and have about 1 000 000 writes…
Probably it writes new value for “last logged in” (or whatever it’s called) so it can print critical logs which will happen between now and next login at next login.
As I remember, ROS collect only unsuccessful “last login”…
But is any ideas how to disable it? :slight_smile:
