I want to use a mikrotik router while i’m travelling, but want an encrypted connection that routes all my traffic back to my home connection (also on a mikrotik) so i can isolate myself from anyone else on the network at the locations i will be staying, as well as being able to access my local LAN resources as if i were there sitting at home.
i already know how to set up an EOIP tunnel and can get that working just fine, but unless i’m mistaken, it is not encrypted. i know that it is possible to run this EOIP tunnel over another tunneling protocol like L2TP, but i’m having trouble figuring out exactly how to get the L2TP connection set up to use with EOIP.
i know i need to set up a server on my home mikrotik, and a client on my mobile mikrotik, but have never dealt with L2TP before at all, much less on a mikrotik. does anyone have some steps for me to follow to do this, and is there anything else i need to do other than set up the server and the client? i’m assuming that since L2TP is encrypted, that there will be some sort of username/password authentication method needed, is that done by the same process of setting up the server/client, or is that done separately?
