Secure Server not working
In beta 10 and 11. The access via https:// seems to not work. The page hangs after the login information. The http: server works fine. Is there a solution
I have the same problem.
Is there any solution ?
Mathias
yeah, I reported it some time ago - nothing seems to make it work.
Now the secure server https:// and the secure remote client will not work in the Version 2 release. https:// crashes the server. remote client simply will not connect. This Dude server is running on Windows 2003 Server fully patched.
Are you using the port you set?
Such as this is the way I’d connect if I were local…
https://127.0.0.1:443
