Securing/isolating ports to specific IP
I have a case where the customer has a scope of public IP-addresses.
What i need to do is prevent that the IP-addresses only can be used by a specific physical port i a CRS.
i have attached a PDF to show what i need. Hopefully this is something that is quite easy to setup.
Best regards
Anders
Have a look at thw Switch ACL features on the CRS:
http://wiki.mikrotik.com/wiki/Manual:CRS_features#ACL
AH!
Nice seems to be exactly what im after.
I will try this and get back with the results.
Thanks :smiley:
It will hopefully let you do what you want with using the CPE, thus at wire speed. :slight_smile:
