I have similar problem with my cloudcore router 6.32.2
My input chain firewall rule to block these IP addresses are not working.
The IP is from china.
I disabled vpn configs and the IP is still establishing connections frequently.
Please how do I put an end to this?
oct/10 23:39:02 pptp,info TCP connection established from 183.60.48.25
oct/10 23:39:02 pptp,debug,packet rcvd Start-Control-Connection-Request from 183.60.48.25
oct/10 23:39:02 pptp,debug,packet protocol-version=0x0100
oct/10 23:39:02 pptp,debug,packet framing-capabilities=1
oct/10 23:39:02 pptp,debug,packet bearer-capabilities=1
oct/10 23:39:02 pptp,debug,packet maximum-channels=0
oct/10 23:39:02 pptp,debug,packet firmware-revision=0
oct/10 23:39:02 pptp,debug,packet host-name=
oct/10 23:39:02 pptp,debug,packet vendor-name=
oct/10 23:39:02 pptp,debug,packet sent Start-Control-Connection-Reply to 183.60.48.25
oct/10 23:39:02 pptp,debug,packet result-code=1
oct/10 23:39:02 pptp,debug,packet error-code=0
oct/10 23:39:02 pptp,debug,packet framing-capabilities=2
oct/10 23:39:02 pptp,debug,packet bearer-capabilities=0
oct/10 23:39:02 pptp,debug,packet firmware-revision=1
oct/10 23:39:02 pptp,debug,packet host-name=KVPROUTER2
oct/10 23:39:02 pptp,debug,packet vendor-name=MikroTik
oct/10 23:39:02 pptp,ppp,debug <9>: LCP lowerdown
oct/10 23:39:02 pptp,ppp,debug <9>: LCP down event in initial state
oct/11 04:29:10 pptp,info TCP connection established from 141.105.66.185
oct/11 04:29:10 pptp,debug received too big control message, disconnecting
oct/11 04:29:10 pptp,ppp,debug <10>: LCP lowerdown
oct/11 04:29:10 pptp,ppp,debug <10>: LCP down event in initial state
oct/11 08:06:05 pptp,info TCP connection established from 183.60.48.25
oct/11 08:06:05 pptp,debug,packet rcvd Start-Control-Connection-Request from 183.60.48.25
oct/11 08:06:05 pptp,debug,packet protocol-version=0x0100
oct/11 08:06:05 pptp,debug,packet framing-capabilities=1
oct/11 08:06:05 pptp,debug,packet bearer-capabilities=1
oct/11 08:06:05 pptp,debug,packet maximum-channels=0
oct/11 08:06:05 pptp,debug,packet firmware-revision=0
oct/11 08:06:05 pptp,debug,packet host-name=
oct/11 08:06:05 pptp,debug,packet vendor-name=
oct/11 08:06:05 pptp,debug,packet sent Start-Control-Connection-Reply to 183.60.48.25
oct/11 08:06:05 pptp,debug,packet result-code=1
oct/11 08:06:05 pptp,debug,packet error-code=0
oct/11 08:06:05 pptp,debug,packet framing-capabilities=2
oct/11 08:06:05 pptp,debug,packet bearer-capabilities=0
oct/11 08:06:05 pptp,debug,packet firmware-revision=1
oct/11 08:06:05 pptp,debug,packet host-name=KVPROUTER2
oct/11 08:06:05 pptp,debug,packet vendor-name=MikroTik
oct/11 08:06:05 pptp,ppp,debug <11>: LCP lowerdown
oct/11 08:06:05 pptp,ppp,debug <11>: LCP down event in initial state
oct/11 16:33:08 pptp,info TCP connection established from 183.60.48.25
oct/11 16:33:08 pptp,debug,packet rcvd Start-Control-Connection-Request from 183.60.48.25
oct/11 16:33:08 pptp,debug,packet protocol-version=0x0100
oct/11 16:33:08 pptp,debug,packet framing-capabilities=1
oct/11 16:33:08 pptp,debug,packet bearer-capabilities=1
oct/11 16:33:08 pptp,debug,packet maximum-channels=0
oct/11 16:33:08 pptp,debug,packet firmware-revision=0
oct/11 16:33:08 pptp,debug,packet host-name=
oct/11 16:33:08 pptp,debug,packet vendor-name=
oct/11 16:33:08 pptp,debug,packet sent Start-Control-Connection-Reply to 183.60.48.25
oct/11 16:33:08 pptp,debug,packet result-code=1
oct/11 16:33:08 pptp,debug,packet error-code=0
oct/11 16:33:08 pptp,debug,packet framing-capabilities=2
oct/11 16:33:08 pptp,debug,packet bearer-capabilities=0
oct/11 16:33:08 pptp,debug,packet firmware-revision=1
oct/11 16:33:08 pptp,debug,packet host-name=KVPROUTER2
oct/11 16:33:08 pptp,debug,packet vendor-name=MikroTik
oct/11 16:33:08 pptp,ppp,debug <12>: LCP lowerdown
oct/11 16:33:08 pptp,ppp,debug <12>: LCP down event in initial state
01:01:18 pptp,info TCP connection established from 183.60.48.25
01:01:18 pptp,debug,packet rcvd Start-Control-Connection-Request from 183.60.48.25
01:01:18 pptp,debug,packet protocol-version=0x0100
01:01:18 pptp,debug,packet framing-capabilities=1
01:01:18 pptp,debug,packet bearer-capabilities=1
01:01:18 pptp,debug,packet maximum-channels=0
01:01:18 pptp,debug,packet firmware-revision=0
01:01:18 pptp,debug,packet host-name=
01:01:18 pptp,debug,packet vendor-name=
01:01:18 pptp,debug,packet sent Start-Control-Connection-Reply to 183.60.48.25
01:01:18 pptp,debug,packet result-code=1
01:01:18 pptp,debug,packet error-code=0
01:01:18 pptp,debug,packet framing-capabilities=2
01:01:18 pptp,debug,packet bearer-capabilities=0
01:01:18 pptp,debug,packet firmware-revision=1
01:01:18 pptp,debug,packet host-name=KVPROUTER2
01:01:18 pptp,debug,packet vendor-name=MikroTik
01:01:18 pptp,ppp,debug <13>: LCP lowerdown
01:01:18 pptp,ppp,debug <13>: LCP down event in initial state
04:14:41 pptp,info TCP connection established from 61.240.144.67
04:15:11 pptp,ppp,debug <14>: LCP lowerdown
04:15:11 pptp,ppp,debug <14>: LCP down event in initial state
04:47:12 pptp,info TCP connection established from 183.60.48.25
04:47:12 pptp,debug,packet rcvd Start-Control-Connection-Request from 183.60.48.25
04:47:12 pptp,debug,packet protocol-version=0x0100
04:47:12 pptp,debug,packet framing-capabilities=1
04:47:12 pptp,debug,packet bearer-capabilities=1
04:47:12 pptp,debug,packet maximum-channels=0
04:47:12 pptp,debug,packet firmware-revision=0
04:47:12 pptp,debug,packet host-name=
04:47:12 pptp,debug,packet vendor-name=
04:47:12 pptp,debug,packet sent Start-Control-Connection-Reply to 183.60.48.25
04:47:12 pptp,debug,packet result-code=1
04:47:12 pptp,debug,packet error-code=0
04:47:12 pptp,debug,packet framing-capabilities=2
04:47:12 pptp,debug,packet bearer-capabilities=0
04:47:12 pptp,debug,packet firmware-revision=1
04:47:12 pptp,debug,packet host-name=KVPROUTER2
04:47:12 pptp,debug,packet vendor-name=MikroTik
04:47:12 pptp,ppp,debug <15>: LCP lowerdown
04:47:12 pptp,ppp,debug <15>: LCP down event in initial state
