if you dont see them on all the routers there could be a few reasons.
- snmp isnt polling correctly
- username password could be incorrect,
confirm that when you double click on the device you can see all the details under the SNMP tab, thats a great first step, what ver Dude are you using?
remember that device performance is an subfunction with the following code
if(
string_size(cpu_mem_disk()) > 0,
concatenate(cpu_mem_disk(), "
and cpu_mem_disk is a subfunction as well.
concatenate(
if(cpu_usage_available(), concatenate("cpu: ", cpu_usage(), "% "), ""),
if(mem_usage() > 0, concatenate("mem: ", round(mem_usage()), "% "), ""),
if(virtual_mem_usage() > 0, concatenate("virt: ", round(virtual_mem_usage()), "% "), ""),
if(hdd_usage() > 0, concatenate("disk: ", round(hdd_usage()), "% "), "")
and then finally hdd_usage is another subfucntion.
oid(concatenate("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.",
array_element(
oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageIndex", 600),
array_find(
oid_column("iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageType", 600),
"iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTypes.hrStorageFixedDisk"
* 100 / hdd_size()
so what i am basically saying is you can do what you want, if you are not getting snmp data, you wont have any detials of the HDD size/usage,
but knowing this you can also use just what you want and save the dude a lot of processing time.
