Software upgrade makes the equipment work unstable. Now I want to upgrade or downgrade other versions, but I can’t finish it. Uploading multiple other versions doesn’t work. I don’t know the problem there.
Attempt to install failed to detect a device in etherboot mode
It is found that the ether1 interface is unable to log in to winbox, but it works normally as a WAN port
