Seems like MikroTik blocks new input WAN connections
Good day!
Need yours help, I encountered the following problem with my MikroTik router (951ui-2hnd, RouterOS mipsbe v6.17, RouterBoard 3.18) and could not solve it.
Problem:
After few minutes DC or Torrents downloading router losts connection with the ISP gateway. Active sessions will not be disconnected but no new connections will be established. Download speed gradually decreases from 10 mb to 3-4 and less.
Same problem appears after 2-3 times bandwich testing on speedtest.net in a row. On the first run speed is maximal, on the second it decrease ~twice until eventually the Internet connection is completely disappears.
Diagnostic:
By netwaching ISP gateway I found that connection losts for exactly 5 minutes every time. At the moment netwatch logs ISP gateway down CPU usage maximum less then 30%, maximum amount of connections less then 300 and there is enough of free mem.
At these 5 minutes defualt route could be deleted and created again ISP gateway (nexthop) is at reacheable state. And there will be input-output traffic.
Seems like MikroTik ignore or ISP gate blocks new input WAN connections. If I connect PC without router problem disappears, everything works fine.
Router seems OK. ARP table seems ok. Ammount of packets seems ok (there is no flood). And as far as I can judge heatsink is ok to. Firewall rules is very simple.
It will not help if I disable-enable WAN interface but if I reboot router entirely by switching power on-off new connections could be established again before 5 minutes have elapsed.
Conf:
jul/28/2014 19:44:12 by RouterOS 6.17
software id = QYH4-KWD1
set [ find default-name=ether1 ] comment=wan mac-address=00:05:5D:6B:BD:8A
name=eth1-wan
set [ find default-name=ether2 ] comment=lan name=eth2
set [ find default-name=ether3 ] master-port=eth2 name=eth3
set [ find default-name=ether4 ] master-port=eth2 name=eth4
set [ find default-name=ether5 ] master-port=eth2 name=eth5
add l2mtu=1598 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode
band=2ghz-b/g/n comment=wifi country=russia disabled=no
disconnect-timeout=9s distance=indoors frequency=2472 ht-rxchains=0
ht-txchains=0 l2mtu=2290 mode=ap-bridge mtu=1492 rate-set=configured
ssid=ssid tx-power=7 tx-power-mode=all-rates-fixed wireless-protocol=
802.11
/interface wireless nstreme
set wlan1 comment=wifi
/interface wireless manual-tx-power-table
/ip neighbor discovery
set eth1-wan comment=wan discover=no
set eth2 comment=lan
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“” mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=1112311
wpa2-pre-shared-key=1112311
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge-local name=dhcp-server
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge-local interface=eth2
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment=local interface=eth2 network=192.168.88.0
add address=$my-host-ip/30 comment=“my ext ip” interface=eth1-wan
network=$my-network
/ip arp
add address=$my-gateway-ip interface=eth1-wan mac-address=C8:4C:75:E9:29:BF
add address=192.168.88.253 interface=bridge-local mac-address=
00:05:5D:6B:BD:8A
add address=192.168.88.23 interface=bridge-local mac-address=
18:E2:C2:E5:0B:D4
add address=192.168.88.25 interface=bridge-local mac-address=
74:D0:2B:A7:8D:9C
add address=192.168.88.21 interface=bridge-local mac-address=
20:10:7A:9D:EB:81
add address=192.168.88.22 interface=bridge-local mac-address=
60:FE:C5:CE:AA:89
add address=192.168.88.18 interface=bridge-local mac-address=
00:EE:BD:63:7E:48
/ip dhcp-server lease
add address=192.168.88.253 client-id=1:0:5:5d:6b:bd:8a comment=pc
mac-address=00:05:5D:6B:BD:8A server=dhcp-server
add address=192.168.88.25 comment=asus mac-address=74:D0:2B:A7:8D:9C server=
dhcp-server
add address=192.168.88.23 client-id=1:18:e2:c2:e5:b:d4 comment=samsung
mac-address=18:E2:C2:E5:0B:D4 server=dhcp-server
add address=192.168.88.22 client-id=1:60:fe:c5:ce:aa:89 comment=ipad
mac-address=60:FE:C5:CE:AA:89 server=dhcp-server
add address=192.168.88.21 client-id=1:20:10:7a:9d:eb:81 mac-address=
20:10:7A:9D:EB:81 server=dhcp-server
add address=192.168.88.20 client-id=1:ec:17:2f:76:e1:35 comment=“mercury pc”
mac-address=EC:17:2F:76:E1:35 server=dhcp-server
add address=192.168.88.19 client-id=1:0:ee:bd:60:3e:d8 mac-address=
00:EE:BD:60:3E:D8 server=dhcp-server
add address=192.168.88.0/24 dns-server=80.65.20.1,80.65.16.1 gateway=
192.168.88.1 netmask=24
set allow-remote-requests=yes servers=80.65.16.1,80.65.20.1
/ip dns static
add address=192.168.88.253 name=PODVAL
/ip firewall address-list
add address=192.168.88.253 list=pc
add address=192.168.88.25 list=asus
add address=192.168.88.23 list=samsung
add address=127.0.0.0/8 list=LOOP
add address=192.168.88.0/24 list=LOCAL
add address=$my-workip list=work
add address=192.168.88.21 list=philips
add address=192.168.88.22 list=ipad
add address=192.168.88.18 list=htc
add chain=forward comment=“forward established accept” connection-state=
established
add chain=forward comment=“forward new out eth1-wan from LOCAL”
connection-state=new out-interface=eth1-wan src-address-list=LOCAL
add chain=forward comment=“uTorrent - forward new udp con from eth1-wan "
connection-state=new dst-address=192.168.88.253 dst-port=38791 protocol=
udp
add chain=forward comment=“FileZilla - forward new tcp con from eth1-wan "
connection-state=new dst-address=192.168.88.253 dst-port=65421 protocol=
tcp
add chain=forward comment=“uTorrent - forward new con from eth1-wan 38791”
tcp
“FlyLinkDC - forward new tcp con from eth1-wan 30100” connection-state=
new dst-address=192.168.88.253 dst-port=30100 protocol=tcp
“FlyLinkDC - forward new udp con from eth1-wan 30200” connection-state=
new dst-address=192.168.88.253 dst-port=30200 protocol=udp
“FlyLinkDC - forward new udp con from eth1-wan 30300” connection-state=
new dst-address=192.168.88.253 dst-port=30300 protocol=udp
add chain=forward comment=“forward related” connection-state=related
add action=drop chain=forward comment=“forward drop invalid”
connection-state=invalid
add action=drop chain=forward comment=“forward drop all”
add chain=input comment=“input local established” connection-state=
established in-interface=!eth1-wan
add chain=input comment=“input eth1-wan established” connection-state=
established in-interface=eth1-wan
add chain=input comment=“input local eth2” in-interface=eth2
add chain=input comment=“input local wlan” in-interface=wlan1
add chain=input comment=“input related” connection-state=related
add action=jump chain=input comment=“input jump work” connection-state=new
jump-target=work src-address-list=work
add chain=work comment=“input accept work”
add chain=input comment=“input icmp” protocol=icmp
add action=drop chain=input comment=“input drop invalid” connection-state=
invalid in-interface=eth1-wan
add action=drop chain=input comment=“input drop all wan” in-interface=
eth1-wan
add chain=output comment=“output local” out-interface=!eth1-wan
add chain=output comment=“output wan” out-interface=eth1-wan
add action=drop chain=output comment=“output drop all”
add action=masquerade chain=srcnat comment=snat out-interface=eth1-wan
src-address-list=LOCAL to-addresses=$my-host-ip
add action=dst-nat chain=dstnat comment=“torrent 38791 tcp” dst-port=38791
in-interface=eth1-wan protocol=tcp to-addresses=192.168.88.253 to-ports=
38791
add action=dst-nat chain=dstnat comment=“filezilla 65421 tcp” dst-port=65421
65421
add action=dst-nat chain=dstnat comment=“torrent 38791 udp” dst-port=38791
in-interface=eth1-wan protocol=udp to-addresses=192.168.88.253 to-ports=
38791
add action=dst-nat chain=dstnat comment=“flylink dc 30100 tcp” dst-port=30100
30100
add action=dst-nat chain=dstnat comment=“flylink dc 30200 udp” dst-port=30200
30200
add action=dst-nat chain=dstnat comment=“flylink dc 30300 dht” dst-port=30300
30300
add action=jump chain=dstnat comment=upnp disabled=yes jump-target=natupmp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec policy
add template=yes
/ip proxy
set parent-proxy=0.0.0.0
add distance=1 gateway=$my-gateway-ip
/ip service
set telnet disabled=yes
set www address=192.168.88.0/24
set ssh disabled=yes
set api address=192.168.88.0/24 disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip smb
set allow-guests=no interfaces=bridge-local
/ip traffic-flow
set cache-entries=1M interfaces=wlan1
/ip traffic-flow target
add address=192.168.88.253:9996 version=9
/ip upnp
set allow-disable-external-interface=no
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=eth5 type=internal
add interface=eth4 type=internal
add interface=eth3 type=internal
add interface=eth2 type=internal
add interface=eth1-wan type=external
/system clock manual
set time-zone=+08:00
/system identity
set name=PODVAL
/system leds
set 0 interface=wlan1
/system logging
add topics=critical
add action=echo topics=error
add action=echo topics=warning
add topics=interface
add topics=firewall
add topics=wireless
add prefix=diag topics=route,event,packet,rsvp,sstp,state
/system ntp client
set enabled=yes primary-ntp=193.27.209.1 secondary-ntp=193.27.209.211
/system routerboard settings
set cpu-frequency=700MHz
/system scheduler
add disabled=yes interval=15m name=wifi_powerdown on-event=”# Script to turn d
own radio power based on a schedule\r
\n# Schedule this script to run every 10-15 minutes to make\r
\n# certain the changeover has occurred.\r
\n# User variables are listed below\r
\n\r
\n#####################################\r
\n## Set the Radio HighPower and LowPower times here ##\r
\n:local RadioHighPowerTime "06:45";\r
\n:local RadioLowPowerTime "00:15";\r
\n:local LowPower 1;\r
\n:local HighPower 12;\r
\n:local RadioName "wlan1";\r
\n:local RadioPowerCut;\r
\n:local RadioPower;\r
\n:local UseNTPClientStatus "no";\r
\n# set to "no" if clock is being set manually after each reboot #\r
\n# set to "yes" if clock is being set using NTP client #\r
\n\r
\n\r
\n#:log info "RadioHighLow Script Starting";\r
\n#:log info "Radio Name = $RadioName";\r
\n\r
\n# First check if system clock has been syncronized with local time #\r
\n:local NTPSyncState [/system ntp client get status];\r
\n#:log info "NTP Client Status = $NTPSyncState";\r
\n\r
\n# Don’t perform radio HighPower or LowPower operation, if current real t
ime is unknown\r
\n# May disable this by adjusting UseNTPClientStatus variable\r
\n:if (($NTPSyncState="synchronized") or ($UseNTPClientStatus="no"))
_do {\r
\n# :log info "NTP okay";\r
\n :local CurrentTime [/system clock get time];\r
\n# :log info "Current Time = $CurrentTime";\r
\n :set RadioPower [:put [/interface wireless get value-name=tx-power
$RadioName]];\r
\n# :log info "Radio Power = $RadioPower";\r
\n :if ($RadioPower = $LowPower) do {\r
\n :set RadioPowerCut true;\r
\n } else {\r
\n :set RadioPowerCut false;\r
\n }\r
\n# :log info "Radio PowerCut = $RadioPowerCut";\r
\n :log info "Current Time = $CurrentTime / Radio Power =
_$RadioPower / Radio PowerCut = $RadioPowerCut";\r
\n\r
\n# Where the HighPower time is set earlier than the LowPower time #\r
\n :if ($RadioHighPowerTime < $RadioLowPowerTime) do {\r
\n\r
\n# Radio should be HighPower between these times #\r
\n :if (($CurrentTime > $RadioHighPowerTime) and ($CurrentTime <
_$RadioLowPowerTime)) do {\r
\n\r
\n :if ($RadioPowerCut=true) do {\r
\n :log info "Radio was LowPower, now switching HighPower
";\r
\n :put [/interface wireless set $RadioName tx-power=$Hig
hPower];\r
\n :put [/interface wireless enable wlan];\r
\n }\r
\n } else {\r
\n\r
\n :if ($RadioPowerCut=false) do {\r
\n :log info "Radio was HighPower, now switching LowPower
";\r
\n :put [/interface wireless set $RadioName tx-power=$Low
Power];\r
\n :put [/interface wireless disable wlan];\r
\n }\r
\n }\r
\n }\r
\n\r
\n# Where the HighPower time is set later than the LowPower time #\r
\n :if ($RadioHighPowerTime > $RadioLowPowerTime) do {\r
\n\r
\n# Radio should be LowPower between these times #\r
\n :if (($CurrentTime < $RadioHighPowerTime) and ($CurrentTime >
\n\r
";\r
Power];\r
\n }\r
\n } else {\r
";\r
hPower];\r
\n }\r
\n\r
\n }\r
\n }\r
\n\r
\n#} else {\r
\n# :log info "System clock problem, unable to perform operation";\r
\n}\r
\n\r
\n#:log info "RadioHighLow Script completed";” policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=jan/01/1970 start-time=00:30:00
add disabled=yes interval=1d name=WiFiOff on-event=“/interface disable wlan1”
policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=
jan/01/1970 start-time=00:45:00
add disabled=yes interval=1d name=WiFiOn on-event=“/interface enable wlan1”
policy=
start-date=jan/01/1970 start-time=06:45:00
/tool bandwidth-server
set authenticate=no
/tool graphing resource
add store-on-disk=no
/tool mac-server
add disabled=yes interface=bridge-local
add interface=eth2
/tool mac-server mac-winbox
add interface=eth2
/tool netwatch
add comment=gw down-script=“:log warning "### NetWatch - Gate $my-gateway-ip
_Down ###";\r
\n:log warning "CPU: $[/system resource get cpu-load]%";\r
\n:log warning "RAM: $(([/system resource get total-memory]-[/system res
ource get free-memory])/1024)/$([/system resource get total-memory]/1024)
M";\r
\n:log warning "CON: $[/ip firewall connection tracking get total-entrie
s]";\r
\n:beep;” host=$my-gateway-ip interval=1s timeout=500ms up-script=
“:log warning "### NetWatch - Gate Up ###";\r
\n:beep;”
/tool sniffer
set filter-interface=eth1-wan memory-limit=1000KiB only-headers=yes
[/spoiler]note 1 filezilla will not work with these rules 2 I disabled dns remote requests
log:
  • [spoiler=my_log_sample]
    22:48:54 system,info,account user admin logged in from 192.168.88.253 via telnet
    22:49:12 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    22:49:12 script,warning CPU: 2%
    22:49:12 script,warning RAM: 24160/131072M
    22:49:12 script,warning CON: 24
    22:50:59 system,info,account user admin logged in from 192.168.88.253 via telnet
    22:54:00 script,warning ### NetWatch - Gate Up ###
    22:56:41 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    22:56:41 script,warning CPU: 3%
    22:56:41 script,warning RAM: 24280/131072M
    22:56:41 script,warning CON: 20
    23:01:10 script,warning ### NetWatch - Gate Up ###
    23:03:25 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    23:03:25 script,warning CPU: 1%
    23:03:25 script,warning RAM: 24328/131072M
    23:03:25 script,warning CON: 17
    23:08:20 script,warning ### NetWatch - Gate Up ###
    23:09:09 wireless,info 00:EE:BD:63:7E:48@wlan1: disconnected, received disassoc: sendi
    ng station leaving (8)
    23:09:09 wireless,info wlan1: data from unknown device 00:EE:BD:63:7E:48, sent deauth
    23:11:21 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    23:11:21 script,warning CPU: 0%
    23:11:21 script,warning RAM: 24308/131072M
    23:11:21 script,warning CON: 17
    23:16:13 script,warning ### NetWatch - Gate Up ###
    23:24:01 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    23:24:01 script,warning CPU: 3%
    23:24:01 script,warning RAM: 24292/131072M
    23:24:01 script,warning CON: 22
    23:28:24 script,warning ### NetWatch - Gate Up ###
    23:33:08 script,warning ### NetWatch - Gate 109.226.228.146 Down ###
    23:33:08 script,warning CPU: 2%
    23:33:08 script,warning RAM: 24352/131072M
    23:33:08 script,warning CON: 16
    23:37:42 script,warning ### NetWatch - Gate Up ###
    23:38:53 system,info,account user admin logged in from 192.168.88.253 via telnet
Need help:
What could be the reason of such behaviour?
What can I do to determine the reason?
What additional information should I give?
problem partly solved! it is in clone mac
