I ended up using many VLAN's and DHCP scopes... Here is my config from the CCR (6.35) and one CRS (6.35)
########################### CCR ###########################################
[admin@SBN-HOF-GW01] /ip firewall nat> / export hide-sensitive
may/16/2016 17:07:40 by RouterOS 6.35.2
software id = GX11-41Y3
add name=bridge-mgmt
add name=bridge-wlan
set [ find default-name=sfp1 ] name=sfp1-gateway
/interface vlan
add interface=ether2 name=VLAN0101-ETH2 vlan-id=101
add interface=ether2 name=VLAN0102-ETH2 vlan-id=102
add interface=ether2 name=VLAN0103-ETH2 vlan-id=103
add interface=ether2 name=VLAN0104-ETH2 vlan-id=104
add interface=ether2 name=VLAN0201-ETH2 vlan-id=201
add interface=ether2 name=VLAN0202-ETH2 vlan-id=202
add interface=ether2 name=VLAN0203-ETH2 vlan-id=203
add interface=ether2 name=VLAN0204-ETH2 vlan-id=204
add interface=ether2 name=VLAN0301-ETH2 vlan-id=301
add interface=ether2 name=VLAN0302-ETH2 vlan-id=302
add interface=ether2 name=VLAN0303-ETH2 vlan-id=303
add interface=ether2 name=VLAN0304-ETH2 vlan-id=304
add interface=ether2 name=VLAN0401-ETH2 vlan-id=401
add interface=ether2 name=VLAN0402-ETH2 vlan-id=402
add interface=ether2 name=VLAN0403-ETH2 vlan-id=403
add interface=ether2 name=VLAN0404-ETH2 vlan-id=404
add interface=ether3 name=VLAN0501-ETH3 vlan-id=501
add interface=ether3 name=VLAN0502-ETH3 vlan-id=502
add interface=ether3 name=VLAN0503-ETH3 vlan-id=503
add interface=ether3 name=VLAN0504-ETH3 vlan-id=504
add interface=ether3 name=VLAN0601-ETH3 vlan-id=601
add interface=ether3 name=VLAN0602-ETH3 vlan-id=602
add interface=ether3 name=VLAN0603-ETH3 vlan-id=603
add interface=ether3 name=VLAN0604-ETH3 vlan-id=604
add interface=ether3 name=VLAN0701-ETH3 vlan-id=701
add interface=ether3 name=VLAN0702-ETH3 vlan-id=702
add interface=ether3 name=VLAN0703-ETH3 vlan-id=703
add interface=ether3 name=VLAN0704-ETH3 vlan-id=704
add interface=ether3 name=VLAN0801-ETH3 vlan-id=801
add interface=ether3 name=VLAN0802-ETH3 vlan-id=802
add interface=ether3 name=VLAN0803-ETH3 vlan-id=803
add interface=ether3 name=VLAN0804-ETH3 vlan-id=804
add interface=ether4 name=VLAN0901-ETH4 vlan-id=901
add interface=ether4 name=VLAN0902-ETH4 vlan-id=902
add interface=ether4 name=VLAN0903-ETH4 vlan-id=903
add interface=ether4 name=VLAN0904-ETH4 vlan-id=904
add interface=ether4 name=VLAN1001-ETH4 vlan-id=1001
add interface=ether4 name=VLAN1002-ETH4 vlan-id=1002
add interface=ether4 name=VLAN1003-ETH4 vlan-id=1003
add interface=ether4 name=VLAN1004-ETH4 vlan-id=1004
add interface=ether4 name=VLAN1101-ETH4 vlan-id=1101
add interface=ether4 name=VLAN1102-ETH4 vlan-id=1102
add interface=ether4 name=VLAN1103-ETH4 vlan-id=1103
add interface=ether4 name=VLAN1104-ETH4 vlan-id=1104
add interface=ether4 name=VLAN1201-ETH4 vlan-id=1201
add interface=ether4 name=VLAN1202-ETH4 vlan-id=1202
add interface=ether4 name=VLAN1203-ETH4 vlan-id=1203
add interface=ether4 name=VLAN1204-ETH4 vlan-id=1204
add interface=ether1 name=VLAN4094-ETH1-MGMT vlan-id=4094
add interface=ether2 name=VLAN4094-ETH2-MGMT vlan-id=4094
add interface=ether3 name=VLAN4094-ETH3-MGMT vlan-id=4094
add interface=ether4 name=VLAN4094-ETH4-MGMT vlan-id=4094
add interface=ether5 name=VLAN4094-ETH5-MGMT vlan-id=4094
add interface=ether6 name=VLAN4094-ETH6-MGMT vlan-id=4094
add interface=ether7 name=VLAN4094-ETH7-MGMT vlan-id=4094
add interface=sfp1-gateway name=sfp1-gateway-V0339 vlan-id=339
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp_pool1 ranges=10.1.1.99-10.1.1.240
add name=dhcp_pool2 ranges=10.1.2.2-10.1.2.254
add name=dhcp_pool3 ranges=10.1.3.2-10.1.3.254
add name=dhcp_pool4 ranges=10.1.4.2-10.1.4.254
add name=dhcp_pool5 ranges=10.2.1.2-10.2.1.254
add name=dhcp_pool6 ranges=10.2.2.2-10.2.2.254
add name=dhcp_pool7 ranges=10.2.3.2-10.2.3.254
add name=dhcp_pool8 ranges=10.2.4.2-10.2.4.254
add name=dhcp_pool9 ranges=10.3.1.2-10.3.1.254
add name=dhcp_pool10 ranges=10.3.2.2-10.3.2.254
add name=dhcp_pool11 ranges=10.3.3.2-10.3.3.254
add name=dhcp_pool12 ranges=10.3.4.2-10.3.4.254
add name=dhcp_pool13 ranges=10.4.1.2-10.4.1.254
add name=dhcp_pool14 ranges=10.4.2.2-10.4.2.254
add name=dhcp_pool15 ranges=10.4.3.2-10.4.3.254
add name=dhcp_pool16 ranges=10.4.4.2-10.4.4.254
add name=dhcp_pool17 ranges=10.5.1.2-10.5.1.254
add name=dhcp_pool18 ranges=10.5.2.2-10.5.2.254
add name=dhcp_pool19 ranges=10.5.3.2-10.5.3.254
add name=dhcp_pool20 ranges=10.5.4.2-10.5.4.254
add name=dhcp_pool21 ranges=10.6.1.2-10.6.1.254
add name=dhcp_pool22 ranges=10.6.2.2-10.6.2.254
add name=dhcp_pool23 ranges=10.6.3.2-10.6.3.254
add name=dhcp_pool24 ranges=10.6.4.2-10.6.4.254
add name=dhcp_pool25 ranges=10.7.1.2-10.7.1.254
add name=dhcp_pool26 ranges=10.7.2.2-10.7.2.254
add name=dhcp_pool27 ranges=10.7.3.2-10.7.3.254
add name=dhcp_pool28 ranges=10.7.4.2-10.7.4.254
add name=dhcp_pool29 ranges=10.8.1.2-10.8.1.254
add name=dhcp_pool30 ranges=10.8.2.2-10.8.2.254
add name=dhcp_pool31 ranges=10.8.3.2-10.8.3.254
add name=dhcp_pool32 ranges=10.8.4.2-10.8.4.254
add name=dhcp_pool33 ranges=10.9.1.2-10.9.1.254
add name=dhcp_pool34 ranges=10.9.2.2-10.9.2.254
add name=dhcp_pool35 ranges=10.9.3.2-10.9.3.254
add name=dhcp_pool36 ranges=10.9.4.2-10.9.4.254
add name=dhcp_pool37 ranges=10.10.1.2-10.10.1.254
add name=dhcp_pool38 ranges=10.10.2.2-10.10.2.254
add name=dhcp_pool39 ranges=10.10.3.2-10.10.3.254
add name=dhcp_pool40 ranges=10.10.4.2-10.10.4.254
add name=dhcp_pool41 ranges=10.11.1.2-10.11.1.254
add name=dhcp_pool42 ranges=10.11.2.2-10.11.2.254
add name=dhcp_pool43 ranges=10.11.3.2-10.11.3.254
add name=dhcp_pool44 ranges=10.11.4.2-10.11.4.254
add name=dhcp_pool45 ranges=10.12.1.2-10.12.1.254
add name=dhcp_pool46 ranges=10.12.2.2-10.12.2.254
add name=dhcp_pool47 ranges=10.12.3.2-10.12.3.254
add name=dhcp_pool48 ranges=10.12.4.2-10.12.4.254
add name=dhcp_pool4094 ranges=10.40.94.100-10.40.94.199
add name=dhcp_pool49 ranges=10.40.94.2-10.40.94.254
add address-pool=dhcp_pool1 disabled=no interface=VLAN0101-ETH2 lease-time=8h name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=VLAN0102-ETH2 lease-time=8h name=dhcp2
add address-pool=dhcp_pool3 disabled=no interface=VLAN0103-ETH2 lease-time=8h name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=VLAN0104-ETH2 lease-time=8h name=dhcp4
add address-pool=dhcp_pool5 disabled=no interface=VLAN0201-ETH2 lease-time=8h name=dhcp5
add address-pool=dhcp_pool6 disabled=no interface=VLAN0202-ETH2 lease-time=8h name=dhcp6
add address-pool=dhcp_pool7 disabled=no interface=VLAN0203-ETH2 lease-time=8h name=dhcp7
add address-pool=dhcp_pool8 disabled=no interface=VLAN0204-ETH2 lease-time=8h name=dhcp8
add address-pool=dhcp_pool9 disabled=no interface=VLAN0301-ETH2 lease-time=8h name=dhcp9
add address-pool=dhcp_pool10 disabled=no interface=VLAN0302-ETH2 lease-time=8h name=dhcp10
add address-pool=dhcp_pool11 disabled=no interface=VLAN0303-ETH2 lease-time=8h name=dhcp11
add address-pool=dhcp_pool12 disabled=no interface=VLAN0304-ETH2 lease-time=8h name=dhcp12
add address-pool=dhcp_pool17 disabled=no interface=VLAN0501-ETH3 lease-time=8h name=dhcp17
add address-pool=dhcp_pool18 disabled=no interface=VLAN0502-ETH3 lease-time=8h name=dhcp18
add address-pool=dhcp_pool19 disabled=no interface=VLAN0503-ETH3 lease-time=8h name=dhcp19
add address-pool=dhcp_pool20 disabled=no interface=VLAN0504-ETH3 lease-time=8h name=dhcp20
add address-pool=dhcp_pool21 disabled=no interface=VLAN0601-ETH3 lease-time=8h name=dhcp21
add address-pool=dhcp_pool22 disabled=no interface=VLAN0602-ETH3 lease-time=8h name=dhcp22
add address-pool=dhcp_pool23 disabled=no interface=VLAN0603-ETH3 lease-time=8h name=dhcp23
add address-pool=dhcp_pool24 disabled=no interface=VLAN0604-ETH3 lease-time=8h name=dhcp24
add address-pool=dhcp_pool25 disabled=no interface=VLAN0701-ETH3 lease-time=8h name=dhcp25
add address-pool=dhcp_pool26 disabled=no interface=VLAN0702-ETH3 lease-time=8h name=dhcp26
add address-pool=dhcp_pool27 disabled=no interface=VLAN0703-ETH3 lease-time=8h name=dhcp27
add address-pool=dhcp_pool28 disabled=no interface=VLAN0704-ETH3 lease-time=8h name=dhcp28
add address-pool=dhcp_pool29 disabled=no interface=VLAN0801-ETH3 lease-time=8h name=dhcp29
add address-pool=dhcp_pool30 disabled=no interface=VLAN0802-ETH3 lease-time=8h name=dhcp30
add address-pool=dhcp_pool31 disabled=no interface=VLAN0803-ETH3 lease-time=8h name=dhcp31
add address-pool=dhcp_pool32 disabled=no interface=VLAN0804-ETH3 lease-time=8h name=dhcp32
add address-pool=dhcp_pool33 disabled=no interface=VLAN0901-ETH4 lease-time=8h name=dhcp33
add address-pool=dhcp_pool34 disabled=no interface=VLAN0902-ETH4 lease-time=8h name=dhcp34
add address-pool=dhcp_pool35 disabled=no interface=VLAN0903-ETH4 lease-time=8h name=dhcp35
add address-pool=dhcp_pool36 disabled=no interface=VLAN0904-ETH4 lease-time=8h name=dhcp36
add address-pool=dhcp_pool39 disabled=no interface=VLAN1003-ETH4 lease-time=8h name=dhcp39
add address-pool=dhcp_pool40 disabled=no interface=VLAN1004-ETH4 lease-time=8h name=dhcp40
add address-pool=dhcp_pool41 disabled=no interface=VLAN1101-ETH4 lease-time=8h name=dhcp41
add address-pool=dhcp_pool42 disabled=no interface=VLAN1102-ETH4 lease-time=8h name=dhcp42
add address-pool=dhcp_pool43 disabled=no interface=VLAN1103-ETH4 lease-time=8h name=dhcp43
add address-pool=dhcp_pool44 disabled=no interface=VLAN1104-ETH4 lease-time=8h name=dhcp44
add address-pool=dhcp_pool45 disabled=no interface=VLAN1201-ETH4 lease-time=8h name=dhcp45
add address-pool=dhcp_pool46 disabled=no interface=VLAN1202-ETH4 lease-time=8h name=dhcp46
add address-pool=dhcp_pool47 disabled=no interface=VLAN1203-ETH4 lease-time=8h name=dhcp47
add address-pool=dhcp_pool48 disabled=no interface=VLAN1204-ETH4 lease-time=8h name=dhcp48
add address-pool=dhcp_pool13 disabled=no interface=VLAN0401-ETH2 lease-time=8h name=dhcp13
add address-pool=dhcp_pool14 disabled=no interface=VLAN0402-ETH2 lease-time=8h name=dhcp14
add address-pool=dhcp_pool15 disabled=no interface=VLAN0403-ETH2 lease-time=8h name=dhcp15
add address-pool=dhcp_pool16 disabled=no interface=VLAN0404-ETH2 lease-time=8h name=dhcp16
add address-pool=dhcp_pool37 disabled=no interface=VLAN1001-ETH4 lease-time=8h name=dhcp37
add address-pool=dhcp_pool38 disabled=no interface=VLAN1002-ETH4 lease-time=8h name=dhcp38
add address-pool=dhcp_pool49 disabled=no interface=bridge-wlan lease-time=8h name=dhcp49
/queue tree
add name=queue1 parent=global queue=default
/system logging action
set 3 remote=207.32.225.78
add bridge=bridge-mgmt interface=ether1
add bridge=bridge-mgmt interface=ether2
add bridge=bridge-mgmt interface=ether3
add bridge=bridge-mgmt interface=ether4
add bridge=bridge-mgmt interface=ether5
add bridge=bridge-mgmt interface=ether6
add bridge=bridge-mgmt interface=ether7
add bridge=bridge-mgmt interface=ether8
add bridge=bridge-wlan interface=VLAN4094-ETH1-MGMT
add bridge=bridge-wlan interface=VLAN4094-ETH2-MGMT
add bridge=bridge-wlan interface=VLAN4094-ETH3-MGMT
add bridge=bridge-wlan interface=VLAN4094-ETH4-MGMT
add independent-learning=no ports=ether2 switch=switch1 vlan-id=101
add independent-learning=no ports=ether2 switch=switch1 vlan-id=102
add independent-learning=no ports=ether2 switch=switch1 vlan-id=103
add independent-learning=no ports=ether2 switch=switch1 vlan-id=104
add independent-learning=no ports=ether2 switch=switch1 vlan-id=201
add independent-learning=no ports=ether2 switch=switch1 vlan-id=202
add independent-learning=no ports=ether2 switch=switch1 vlan-id=203
add independent-learning=no ports=ether2 switch=switch1 vlan-id=204
add independent-learning=no ports=ether2 switch=switch1 vlan-id=301
add independent-learning=no ports=ether2 switch=switch1 vlan-id=302
add independent-learning=no ports=ether2 switch=switch1 vlan-id=303
add independent-learning=no ports=ether2 switch=switch1 vlan-id=304
add independent-learning=no ports=ether2 switch=switch1 vlan-id=401
add independent-learning=no ports=ether2 switch=switch1 vlan-id=402
add independent-learning=no ports=ether2 switch=switch1 vlan-id=403
add independent-learning=no ports=ether2 switch=switch1 vlan-id=404
add independent-learning=no ports=ether3 switch=switch1 vlan-id=501
add independent-learning=no ports=ether3 switch=switch1 vlan-id=502
add independent-learning=no ports=ether3 switch=switch1 vlan-id=503
add independent-learning=no ports=ether3 switch=switch1 vlan-id=504
add independent-learning=no ports=ether3 switch=switch1 vlan-id=601
add independent-learning=no ports=ether3 switch=switch1 vlan-id=602
add independent-learning=no ports=ether3 switch=switch1 vlan-id=603
add independent-learning=no ports=ether3 switch=switch1 vlan-id=604
add independent-learning=no ports=ether3 switch=switch1 vlan-id=701
add independent-learning=no ports=ether3 switch=switch1 vlan-id=702
add independent-learning=no ports=ether3 switch=switch1 vlan-id=703
add independent-learning=no ports=ether3 switch=switch1 vlan-id=704
add independent-learning=no ports=ether3 switch=switch1 vlan-id=801
add independent-learning=no ports=ether3 switch=switch1 vlan-id=802
add independent-learning=no ports=ether3 switch=switch1 vlan-id=803
add independent-learning=no ports=ether3 switch=switch1 vlan-id=804
add independent-learning=no ports=ether4 switch=switch1 vlan-id=901
add independent-learning=no ports=ether4 switch=switch1 vlan-id=902
add independent-learning=no ports=ether4 switch=switch1 vlan-id=903
add independent-learning=no ports=ether4 switch=switch1 vlan-id=904
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1001
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1002
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1003
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1004
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1101
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1102
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1103
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1104
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1201
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1202
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1203
add independent-learning=no ports=ether4 switch=switch1 vlan-id=1204
add address=38.123.81.92/29 interface=sfp1-gateway-V0339 network=38.123.81.88
add address=10.1.1.1/24 interface=VLAN0101-ETH2 network=10.1.1.0
add address=10.1.2.1/24 interface=VLAN0102-ETH2 network=10.1.2.0
add address=10.1.3.1/24 interface=VLAN0103-ETH2 network=10.1.3.0
add address=10.1.4.1/24 interface=VLAN0104-ETH2 network=10.1.4.0
add address=10.2.1.1/24 interface=VLAN0201-ETH2 network=10.2.1.0
add address=10.2.2.1/24 interface=VLAN0202-ETH2 network=10.2.2.0
add address=10.2.3.1/24 interface=VLAN0203-ETH2 network=10.2.3.0
add address=10.2.4.1/24 interface=VLAN0204-ETH2 network=10.2.4.0
add address=10.3.1.1/24 interface=VLAN0301-ETH2 network=10.3.1.0
add address=10.3.2.1/24 interface=VLAN0302-ETH2 network=10.3.2.0
add address=10.3.3.1/24 interface=VLAN0303-ETH2 network=10.3.3.0
add address=10.3.4.1/24 interface=VLAN0304-ETH2 network=10.3.4.0
add address=10.0.0.250/24 interface=bridge-mgmt network=10.0.0.0
add address=10.40.94.1/24 interface=bridge-wlan network=10.40.94.0
add address=10.4.1.1/24 interface=VLAN0401-ETH2 network=10.4.1.0
add address=10.4.2.1/24 interface=VLAN0402-ETH2 network=10.4.2.0
add address=10.4.3.1/24 interface=VLAN0403-ETH2 network=10.4.3.0
add address=10.4.4.1/24 interface=VLAN0404-ETH2 network=10.4.4.0
add address=10.5.1.1/24 interface=VLAN0501-ETH3 network=10.5.1.0
add address=10.5.2.1/24 interface=VLAN0502-ETH3 network=10.5.2.0
add address=10.5.3.1/24 interface=VLAN0503-ETH3 network=10.5.3.0
add address=10.5.4.1/24 interface=VLAN0504-ETH3 network=10.5.4.0
add address=10.6.1.1/24 interface=VLAN0601-ETH3 network=10.6.1.0
add address=10.6.2.1/24 interface=VLAN0602-ETH3 network=10.6.2.0
add address=10.6.3.1/24 interface=VLAN0603-ETH3 network=10.6.3.0
add address=10.6.4.1/24 interface=VLAN0604-ETH3 network=10.6.4.0
add address=10.7.1.1/24 interface=VLAN0701-ETH3 network=10.7.1.0
add address=10.7.2.1/24 interface=VLAN0702-ETH3 network=10.7.2.0
add address=10.7.3.1/24 interface=VLAN0703-ETH3 network=10.7.3.0
add address=10.7.4.1/24 interface=VLAN0704-ETH3 network=10.7.4.0
add address=10.8.1.1/24 interface=VLAN0801-ETH3 network=10.8.1.0
add address=10.8.2.1/24 interface=VLAN0802-ETH3 network=10.8.2.0
add address=10.8.3.1/24 interface=VLAN0803-ETH3 network=10.8.3.0
add address=10.8.4.1/24 interface=VLAN0804-ETH3 network=10.8.4.0
add address=10.9.1.1/24 interface=VLAN0901-ETH4 network=10.9.1.0
add address=10.9.2.1/24 interface=VLAN0902-ETH4 network=10.9.2.0
add address=10.9.3.1/24 interface=VLAN0903-ETH4 network=10.9.3.0
add address=10.9.4.1/24 interface=VLAN0904-ETH4 network=10.9.4.0
add address=10.10.1.1/24 interface=VLAN1001-ETH4 network=10.10.1.0
add address=10.10.2.1/24 interface=VLAN1002-ETH4 network=10.10.2.0
add address=10.10.3.1/24 interface=VLAN1003-ETH4 network=10.10.3.0
add address=10.10.4.1/24 interface=VLAN1004-ETH4 network=10.10.4.0
add address=10.11.1.1/24 interface=VLAN1101-ETH4 network=10.11.1.0
add address=10.11.2.1/24 interface=VLAN1102-ETH4 network=10.11.2.0
add address=10.11.3.1/24 interface=VLAN1103-ETH4 network=10.11.3.0
add address=10.11.4.1/24 interface=VLAN1104-ETH4 network=10.11.4.0
add address=10.12.1.1/24 interface=VLAN1201-ETH4 network=10.12.1.0
add address=10.12.2.1/24 interface=VLAN1202-ETH4 network=10.12.2.0
add address=10.12.3.1/24 interface=VLAN1203-ETH4 network=10.12.3.0
add address=10.12.4.1/24 interface=VLAN1204-ETH4 network=10.12.4.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=sfp-sfpplus1
add address=10.0.0.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.0.0.1 netmask=24
add address=10.1.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.1.1.1 netmask=24
add address=10.1.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.1.2.1 netmask=24
add address=10.1.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.1.3.1 netmask=24
add address=10.1.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.1.4.1 netmask=24
add address=10.2.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.2.1.1 netmask=24
add address=10.2.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.2.2.1 netmask=24
add address=10.2.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.2.3.1 netmask=24
add address=10.2.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.2.4.1 netmask=24
add address=10.3.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.3.1.1 netmask=24
add address=10.3.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.3.2.1 netmask=24
add address=10.3.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.3.3.1 netmask=24
add address=10.3.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.3.4.1 netmask=24
add address=10.4.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.4.1.1 netmask=24
add address=10.4.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.4.2.1 netmask=24
add address=10.4.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.4.3.1 netmask=24
add address=10.4.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.4.4.1 netmask=24
add address=10.5.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.5.1.1 netmask=24
add address=10.5.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.5.2.1 netmask=24
add address=10.5.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.5.3.1 netmask=24
add address=10.5.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.5.4.1 netmask=24
add address=10.6.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.6.1.1 netmask=24
add address=10.6.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.6.2.1 netmask=24
add address=10.6.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.6.3.1 netmask=24
add address=10.6.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.6.4.1 netmask=24
add address=10.7.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.7.1.1 netmask=24
add address=10.7.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.7.2.1 netmask=24
add address=10.7.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.7.3.1 netmask=24
add address=10.7.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.7.4.1 netmask=24
add address=10.8.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.8.1.1 netmask=24
add address=10.8.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.8.2.1 netmask=24
add address=10.8.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.8.3.1 netmask=24
add address=10.8.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.8.4.1 netmask=24
add address=10.9.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.9.1.1 netmask=24
add address=10.9.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.9.2.1 netmask=24
add address=10.9.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.9.3.1 netmask=24
add address=10.9.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.9.4.1 netmask=24
add address=10.10.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.10.1.1 netmask=24
add address=10.10.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.10.2.1 netmask=24
add address=10.10.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.10.3.1 netmask=24
add address=10.10.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.10.4.1 netmask=24
add address=10.11.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.11.1.1 netmask=24
add address=10.11.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.11.2.1 netmask=24
add address=10.11.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.11.3.1 netmask=24
add address=10.11.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.11.4.1 netmask=24
add address=10.12.1.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.12.1.1 netmask=24
add address=10.12.2.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.12.2.1 netmask=24
add address=10.12.3.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.12.3.1 netmask=24
add address=10.12.4.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.12.4.1 netmask=24
add address=10.40.94.0/24 dns-server=8.8.8.8,4.2.2.2 gateway=10.40.94.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,4.2.2.2
/ip firewall address-list
add address=10.0.0.0/8 list=RFC1918
add address=172.16.0.0/12 list=RFC1918
add address=192.168.0.0/16 list=RFC1918
add chain=forward comment="Forward Allow MGMT ICMP" dst-address=10.0.0.0/8 protocol=icmp src-address=10.0.0.0/24
add chain=forward comment="Dish Network SmartBox" dst-address=10.0.0.20 dst-port=443 log=yes protocol=tcp
add chain=forward comment="Forward Accept Related and Established" connection-state=established,related
add action=drop chain=forward comment="Forward Drop Inter VLAN traffic" dst-address=10.0.0.0/8 src-address=10.0.0.0/8
add action=drop chain=forward comment="Forward Drop Invalid" connection-state=invalid
add chain=input comment="Input Accept Related and Established" connection-state=established,related
add chain=input in-interface=bridge-mgmt
add chain=input dst-port=22,8291,8000 in-interface=sfp1-gateway-V0339 protocol=tcp
add action=drop chain=input
add action=masquerade chain=srcnat out-interface=sfp1-gateway-V0339
add action=dst-nat chain=dstnat dst-address=38.123.81.92 dst-port=2016 log=yes protocol=tcp to-addresses=10.0.0.20 to-ports=443
add action=masquerade chain=srcnat dst-address=10.1.1.20 dst-port=2016,443 protocol=tcp src-address-list=RFC1918
add chain=srcnat disabled=yes src-address=0.0.0.0
add check-gateway=ping distance=1 gateway=38.123.81.89
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/8 port=8000
set api disabled=yes
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=stat-slideshow
/system clock
set time-zone-name=America/Indiana/Indianapolis
/system identity
set name=SBN-HOF-GW01
/system leds
set 0 interface=sfp-sfpplus1
set 1 interface=sfp-sfpplus1
set 2 interface=sfp1-gateway
/system logging
add action=remote topics=error
/system ntp client
set enabled=yes primary-ntp=207.32.233.1
/system resource irq rps
set sfp-sfpplus1 disabled=no
set sfp1-gateway disabled=no
set ether5 disabled=no
set ether6 disabled=no
set ether7 disabled=no
set ether8 disabled=no
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1066DDR protected-routerboot=disabled
/tool graphing interface
/tool graphing resource
add
/tool romon port
add
############### CRS ####################################
[admin@SBN-HOF-SW06] /interface ethernet> /export hide-sensitive
may/15/2016 17:09:21 by RouterOS 6.35.2
software id = NYIK-0DZ1
add name=bridge1
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether1-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether1-master-local name=ether10-slave-local
set [ find default-name=ether11 ] master-port=ether1-master-local name=ether11-slave-local
set [ find default-name=ether12 ] master-port=ether1-master-local name=ether12-slave-local
set [ find default-name=ether13 ] master-port=ether1-master-local name=ether13-slave-local
set [ find default-name=ether14 ] master-port=ether1-master-local name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-master-local name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-master-local name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-master-local name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-master-local name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-master-local name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-master-local name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-master-local name=ether21-slave-local
set [ find default-name=ether22 ] master-port=ether1-master-local name=ether22-slave-local
set [ find default-name=ether23 ] master-port=ether1-master-local name=ether23-slave-local
set [ find default-name=ether24 ] master-port=ether1-master-local name=ether24-slave-local
set [ find default-name=sfp1 ] master-port=ether1-master-local name=sfp1-slave-local
/ip ipsec proposal
add bridge=bridge1 interface=ether1-master-local
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether24-slave-local vlan-id=501
add tagged-ports=ether24-slave-local vlan-id=502
add tagged-ports=ether24-slave-local vlan-id=503
add tagged-ports=ether24-slave-local vlan-id=504
add tagged-ports=ether24-slave-local vlan-id=601
add tagged-ports=ether24-slave-local vlan-id=602
add tagged-ports=ether24-slave-local vlan-id=603
add tagged-ports=ether24-slave-local vlan-id=604
add tagged-ports=ether24-slave-local vlan-id=701
add tagged-ports=ether24-slave-local vlan-id=702
add tagged-ports=ether24-slave-local vlan-id=703
add tagged-ports=ether24-slave-local vlan-id=704
add tagged-ports=ether24-slave-local vlan-id=801
add tagged-ports=ether24-slave-local vlan-id=802
add tagged-ports=ether24-slave-local vlan-id=803
add tagged-ports=ether24-slave-local vlan-id=804
add tagged-ports=ether24-slave-local vlan-id=4094
/interface ethernet switch ingress-port-policer
add meter-unit=packet packet-types=broadcast port=ether3-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether4-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether5-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether6-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether7-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether8-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether9-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether10-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether11-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether12-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether13-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether14-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether15-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether16-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether17-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether18-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether19-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether20-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether21-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether22-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether23-slave-local rate=500
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether3-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether4-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether5-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether6-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether7-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether8-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether9-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether10-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether11-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether12-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether13-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether14-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether15-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether16-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether17-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether18-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether19-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether20-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether21-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether22-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether23-slave-local rate=5k
add meter-unit=packet packet-types=broadcast port=ether2-slave-local rate=500
add meter-unit=packet packet-types=broadcast port=ether1-master-local rate=500
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether2-slave-local rate=5k
add meter-unit=packet packet-types=arp-or-nd,broadcast,unregistered-multicast port=ether1-master-local rate=5k
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=502 ports=ether2-slave-local
add customer-vid=0 new-customer-vid=503 ports=ether3-slave-local
add customer-vid=0 new-customer-vid=504 ports=ether4-slave-local
add customer-vid=0 new-customer-vid=601 ports=ether5-slave-local
add customer-vid=0 new-customer-vid=602 ports=ether6-slave-local
add customer-vid=0 new-customer-vid=603 ports=ether7-slave-local
add customer-vid=0 new-customer-vid=604 ports=ether8-slave-local
add customer-vid=0 new-customer-vid=701 ports=ether9-slave-local
add customer-vid=0 new-customer-vid=702 ports=ether10-slave-local
add customer-vid=0 new-customer-vid=703 ports=ether11-slave-local
add customer-vid=0 new-customer-vid=704 ports=ether12-slave-local
add customer-vid=0 new-customer-vid=801 ports=ether13-slave-local
add customer-vid=0 new-customer-vid=802 ports=ether14-slave-local
add customer-vid=0 new-customer-vid=803 ports=ether15-slave-local
add customer-vid=0 new-customer-vid=804 ports=ether16-slave-local
add customer-vid=0 new-customer-vid=501 ports=ether1-master-local
add customer-vid=0 new-customer-vid=4094 ports=ether23-slave-local
set 0 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 1 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 2 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 3 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 4 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 5 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 6 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 7 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 8 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 9 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 10 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 11 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 12 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 13 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 14 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 15 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 16 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 17 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 18 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 19 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 20 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 21 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 22 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 23 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 24 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 25 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
add ports=ether1-master-local,ether24-slave-local vlan-id=501
add ports=ether2-slave-local,ether24-slave-local vlan-id=502
add ports=ether3-slave-local,ether24-slave-local vlan-id=503
add ports=ether4-slave-local,ether24-slave-local vlan-id=504
add ports=ether5-slave-local,ether24-slave-local vlan-id=601
add ports=ether6-slave-local,ether24-slave-local vlan-id=602
add ports=ether7-slave-local,ether24-slave-local vlan-id=603
add ports=ether8-slave-local,ether24-slave-local vlan-id=604
add ports=ether9-slave-local,ether24-slave-local vlan-id=701
add ports=ether10-slave-local,ether24-slave-local vlan-id=702
add ports=ether11-slave-local,ether24-slave-local vlan-id=703
add ports=ether12-slave-local,ether24-slave-local vlan-id=704
add ports=ether13-slave-local,ether24-slave-local vlan-id=801
add ports=ether14-slave-local,ether24-slave-local vlan-id=802
add ports=ether15-slave-local,ether24-slave-local vlan-id=803
add ports=ether16-slave-local,ether24-slave-local vlan-id=804
add ports=ether17-slave-local,ether18-slave-local,ether19-slave-local,ether20-slave-local,ether21-slave-local,ether22-slave-local,ether23-slave-local,ether24-slave-local vlan-id=4094
add address=10.0.0.248/24 interface=ether24-slave-local network=10.0.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
set servers=8.8.8.8,4.4.4.4
/system clock
/system identity
set name=SBN-HOF-SW06
set boot-device=flash-boot protected-routerboot=disabled
