Selecting weaker "better" cell with R11e-LT6 ?
I have a number of newbie questions for my R11e-LT6, 6.47.1 .
  1. Scan
    When I do
    /interface lte cell-monitor lte1
    I get the strong cell that gives me about 2Mbit/s (B20)
    But I can manually select a weaker cell (that the scan does not see) that gives me 30Mbit/s (B3)
Should the scan do a better job ?
Am I missing something ?
  1. Is there a way to run a command/script at power up?
  2. Scripting
    Is there a getting started / idiots guide to scripting?
Has someone made a script to switch between two cells depending on, say SINR ?
In my case I’d like to use the B20 when SINR is ok but fall back on B3 when its not.
Then maybe every hour (on B20) check B3.
This would be to adapt to say bad weather or cell going belly up.
  1. Level LEDs
    Can the level LEDs be re-programmed so they are more sensitive and maybe use SINR ?
James
