I have a weird setup I want to try. Let’s say I have two routers and some client on some network.
R1 (DHCP server)
R2 (switch/DHCP-proxy)
Client (LAN)
I want R2 to act like a layer-2 passthrough, so basically a switch between the two ports that connect it to R1 and LAN. However, I want some rule on R2 that creates a 1:1 NAT when some client tries to contact the main gateway so it can be routed to the internet. This way, R1 can handle all DHCP requests and internet routing for packets sent to it, but with R2 acting as a proxy only for packets sent to R1 and to the internet. I would want to do this to make R2 act like a transparent PCC router and not have to touch R1’s settings at all or create a double NAT or have to change anything on the LAN side. Is there a way to do this? I was thinking of creating a simple 1:1 NAT rule where the destination address is !LAN and the routing mark says that the packet should go to R1.
