Selective Routing when using a VPN
Hi
I have a bit of a complex setup to get to the internet. My ISP does not use DHCP so I first have to make a PPPoE connection to the fiber carrier, after which i need to make a L2TP connection to my ISP
to get out onto the internet. I want to use a VPN provider (Nord VPN etc.) for anonymize my internet traffic. I have to use NAT on my router to access servers inside my network, which works like a charm. My question is will I be able to connect to a VPN but at the same time still have my NATed servers available on my static IP from my ISP. I used to use an ASUS RT-AC86U router and it enabled
me me to exclude NATed servers from the VPN tunnel.
Is this possible? Any help will be appreciated.
Kind Regards
Anybody out there? Just nod if you can hear me.
