hi!
I have problem with CPU frequency on my RB532a.
Since ever i’ve got cpu freq set to 399Mhz and routerboard was working just fine (and still it does) but i noticed that cpu is downclocked to 199MHz
After quick lookout over board i’ve found some curved capacitors so i have replaced them all (slighty bigger than oryginal) but after this cpu is still clocled at 199Mhz and i cant change it…
From rs232:
Info:
RouterBOOT booter 2.18
RouterBoard 532A
CPU frequency: 199 MHz
Memory size: 64 MB
Press any key within 5 seconds to enter setup...
RouterBOOT-2.18
your choice: i - board info
Board Info:
Board type: 532A
Serial number: 14FA01D5B5E1
Firmware version: 2.18
Memory size: 64 MB
eth1 MAC address: 00:0C:42:08:ED:56
eth2 MAC address: 00:0C:42:08:ED:57
eth3 MAC address: 00:0C:42:08:ED:58
press any key to continue...
CPU mode (it was alweys on regular…)
RouterBOOT-2.18
What do you want to configure?
your choice: u - cpu mode
CPU mode:
* 1 - power save
2 - regular (better for -0c environment)
your choice: 2 - regular (better for -0c environment)
and for check…
RouterBOOT-2.18
CPU mode:
1 - power save
* 2 - regular (better for -0c environment)
Now CPU freq
RouterBOOT-2.18
your choice: f - try cpu frequency
Try one of supported CPU frequencies:
* 1 - 199MHz
2 - 266MHz
3 - 333MHz
4 - 399MHz
your choice: 4 - 399MHz
please, press reset button to change CPU frequency
now hard power off and CPU is all right
RouterBoard 532A
CPU frequency: 399 MHz
Memory size: 64 MB
RouterBOOT-2.18
Board Info:
Board type: 532A
Memory size: 64 MB
RouterBOOT-2.18
CPU mode:
1 - power save
RouterBOOT-2.18
your choice: x - exit setup
RouterBoard 532A
Memory size: 64 MB
Press any key within 5 seconds to enter setup.....
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 5.5
urbiszcze Login: admin assword:
[admin@urbiszcze] > /system routerboard settings print
baud-rate: 115200
boot-delay: 5s
enter-setup-on: any-key
boot-device: nand-if-fail-then-ethernet
cpu-mode: regular
cpu-frequency: 399MHz
safe-cpu-frequency: 199MHz
boot-protocol: bootp
enable-jumper-reset: yes
[admin@urbiszcze] >
soft reboot. still 399MHz
[admin@urbiszcze] > /system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Rebooting...
Stopping services...
Restarting system.
RouterBoard 532A
Memory size: 64 MB
and after hard power off…
RouterBoard 532A
Memory size: 64 MB
so what now ?
