Senao NL-2511CD+EXT2 Radios not being Recognized
for some reason 2.9.27 does not recognize my senao NL-2511CD+EXT2 pcmcia cards. I mkt is running on a standard pc plataform, and also the ethernet cards are ok. i also run monowall on the same pc, but in a different CF card. monowall loads the driver and works just fine. what could be causing this behaviour? thanks i advance!
I have the same problem, but resolve change the monteboard.
So look!!
that might works! thanks man
