Send all LAN traffic via Mikrotik SSTP client connection?
Is it possible to use SSTP Client connection as gateway for all LAN traffic? Like SSTP tunnel/gateway.
Thanks!
It’s literally the first line in the SSTP client parameter table in the documentation:
https://wiki.mikrotik.com/wiki/Manual:Interface/SSTP#SSTP_Client
UPD: I see that I need to configure NAT rules, add routes as well.
Hello, yes I’ve enabled it, but no traffic is routed via that route :confused: Is it possile to disable RC4 cipher and use something stronger?
