Is it possible for a Routerboard to email me the complete list of DHCP server leases to me every day?
Kris
Kris
This should work:
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
/ip dhcp-server lease;
:foreach i in=[find where server=DHCPSERVER_192 ] do={
:set hostname [get $i host-name];
:set hostip [get $i address];
:set dhcplist ( $dhcplist . $hostname . " " . "$hostip . "\n" )
/tool e-mail send to=somemail@nowhere.com subject="DHCPLIST" body=$dhcplist;
You need to:
So I have this:
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
:foreach i in=[find where server=dhcp1] do={
/tool e-mail send to=info@mymail.eu subject="DHCP Leases KrIsa" body=$dhcplist;
Is this correct? Because that doesn’t seem to work over here.
Another script works well, eg a backup and export to my mailaddress every night.
Somebody elke that know the solution for this problem?
Would be very nice if somebody could help me!
Best regards,
Kris
Somebody? ![]()
Hi there!
The hint “doesn’t seem to work” is not very helpful for debugging this script… but I must say the “Run Script” option in the Scripts dialog of WinBox doesn’t provide any further information.
If you call the script via the terminal, you get a much better explanation for failing:
[admin@MikroTik] > system script run MyScript
syntax error (line 10 column 61)
Which is this line and column:
Just remove the quote before $hostip and it will work.. remember to set the email server under Tools > Email
Checked…there was extra " before $hostip
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
:set dhcplist ($dhcplist . $hostname . " " . $hostip . "\n");
/tool e-mail send to=myaddress subject="DHCPLIST" body=$dhcplist;
If you want to see where is the code error then write script, open CLI, goto /system script and then do print command.
all scripts will be listed with brown block showing syntax error.
That work great!
But is there a possibility to mention the number of DHCP leases on top of it?
I just found this out… At this moment there are 323 connected devices, and 299 of them have an IP from the EOIP pool…
[admin@IT2GO - Router] /ip dhcp-server lease> print count-only
323
[admin@IT2GO - Router] /ip dhcp-server lease> print count-only where server=EOIP
299
But how to i edit it in code for the ROS scriping ![]()
Any tips or idea’s on this one?
Something like this:
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
:local leasesall [ :len [ /ip dhcp-server lease find ] ];
:local leaseseoip [ :len [ /ip dhcp-server lease find where server=EOIP ] ];
/tool e-mail send to=myaddress subject="DHCPLIST" body=( "ALL: " . $leasesall . "\nEOIP: " . $leaseseoip . "\n\n" . $dhcplist );
Wow that did work indeed!
And then…the final question ![]()
Is it possible to also mention the current firmware (system routerboard print) and the winbox version (system package print, column “version”)?
Something like:
ALL: 296
EOIP: 268
Winbox Version: 6.30.2
Firmware: 3.24
Best regards, and tnx for the help!
:local firmware [ /system routerboard get current-firmware ]
:local routeros [ /system package get number=0 value-name=version ]
This works fine, but can MAC-address add to this report?
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
:local leasesall [ :len [ /ip dhcp-server lease find where server=Lan ] ];
:local firmware [ /system routerboard get current-firmware ];
:local routeros [ /system package get number=0 value-name=version ];
:foreach i in=[find where server=Lan ] do={
:set macaddress [get $i active-mac-address];
:set dhcplist ($dhcplist . $hostname . " " . $hostip . " ". $macaddress . "\n");
/tool e-mail send to=info@it2go.eu subject="DHCP Leases KrIsa Lan" body=( "DHCP Leases: " . $leasesall . "\n\n" "Firmware: " . $firmware . "\n\n" "RouterOS: " . $routeros . "\n\n" . $dhcplist );
I “tried” (kuch), but i failed ![]()
I tought that the script above would print me a list like this
DHCP Leases : 200
Firmware : x.y.z
RouterOS : a.b.c
blablabla 10.10.10.10 aa:bb:cc:dd:ee:ff
The only thing it did…
RouterOS: 6.30.2
voip01 10.0.0.11
IT2GO-Fix 10.0.0.101
So it does print the ROS version, the hostname and the ip but it doesn’t count the number of DHCP leases anymore, nor did it mention the firmware version or the mac addresses…
Again : somebody that know the solution? ![]()
If your script does not work the easiest way to check what could be wrong is to check if the syntax is correct.
Tha latest script has errors:
please add at the top… there is no macaddress variable declared so assigning to it fails and script stops:
:local macaddress
and change body text expression…there are missing dots (string concatenation):
("DHCP Leases: $leasesall\nFirmware: $firmware\nRouterOS: $routeros\n" . $dhcplist )
and all should work
Is it possible to find “Busy” from DHCP lease list status apart from “Bound”
yes, but I think you can do a little work, too.
Hint:
[me@somewhere] /ip dhcp-server lease> :foreach i in=[find ] do={ :put [get $i status ] }
waiting
bound
waiting
Can you post the complete script with add MAC-address and ROS please
Plisken,
This should work if you only have one DHCP server
:local i;
:local hostip;
:local hostname;
:local dhcplist "";
:local macaddress;
/tool e-mail send to=your@mail.address subject="Subject of mail" body=( "Amount of DHCP leases: $leasesall\n\nFirmware: $firmware\nRouterOS: $routeros\n\n" . $dhcplist );
