send email error
[admin@3000] > /tool e-mail send from=“wwjun@163.com” to=“wwjun@163.com” server=220.181.31.178 subject=“12345” body=“kdkkdkoe”
then find error:/log print
Error sending e-mail:invalid FROM address
why? my smtp server require authentication. smtp server ip:220.181.31.178
help!!!
thank!
the only way if your server requires smtp auth. is to grant a bypass filter on your server to that particular email address.
i have this setup on my server works fine
one thing though make your bypass email address something like
mtfailed23400133@mailserver.com just so it a little more secure
randy
Hi guys, I´ve the same problem, so late.
Sorry
But I´m not the owner of the Mail Server.
What can I do?
How can I work sort this matter?
Fernando
Apart from MT integrating SMTP AUTH (please!) one thing you can do is sending the e-mail directly to the mailserver hosting your e-mail account. This one will always accept the e-mail…
This could get ugly when using a big mail provider with clustered/load-balanced mail servers, but should work usually…
Best regards,
Christian Meis
Ok thanks for the comment. I´ll try, the important thing wrigth now is to work .
After that we will put in order and nice. Don`t you think?
Ok, after that, I`m trying to search on the manual, and Ì could not be able to find how can I authenticate the Mtk to the Mail Server.
On this moment I`m doing:
server: 200.62.54.104
But, password ???
Do I missing something? Where?
Pls Help me, I`m so stupid on this matter.
THANKS IN ADVANCE
Fernando
If you use the smtp server you quoted and the email address you quoted as destination (to), that should work - this server is the destination mail server for that domain…
There should be no need for any authentication then.
Christian Meis
Crhris, thanks a lot, SOLVED
Fernando
