send mail on changes of configuration
Hi, How can I configure my router in such a way that, - if there is any changes in the router configuration - then it should send mail to particular person.
Thanks in Advance
Prakash
any change??
More info required.
any changes in router means, if anybody changes the routing, or firewall configurations, of adding interfaces or anything like such, the MKT should send email to a perticular person
maybe create a config_backup then create config1_backup and compare it ?
how can I do this through script?
maybe you can somehow get number of lines from the history command? mrz should help, i’m no good at scripting:
[normis@demo2.mt.lv] > system history print
Flags: U - undoable, R - redoable, F - floating-undo
  ACTION                                   BY                 POLICY
U address list entry added                 normis             write
U address list entry removed               normis             write
thanks, I can see the history, but can not see the time and date of the action.
any help
ok, you can customize your logging settings, put the logs to some remote syslog server, which could filter out the important ones, and sms about them. there are many customizable syslog servers out there.
