Hello!
I am sorry for my bad English.
I need send two vlan in “untagged” mode to access port.
I have CRS317.. in sfp16 comes two tagged vlan: 1-internet and dhcp-addressing, 4 - iptv multicast.
My trying One.
I created for physical iface sfp16 two vlans: lan1 pvid=1, lan4 pvid=4. After I created bridge (vlan-filtering=no) and add into: client port sfp14, vlan1, vlan4. I have solution my problem and loop to up swith. After added rule into bridge Filter: drop forwarding traffic between vlan1 and vlan4. After it solution just work. It fine! But… traffic moved and processed in CPU, not switch chip.
My trying Two.
I need traffic processed wired speed, so created bridge br0 (vlan-filtering=yes) and two vlan into bridge. Code:
add igmp-snooping=yes name=br0 protocol-mode=none vlan-filtering=yes
add bridge=br0 interface=sfp-sfpplus16
add bridge=br0 interface=sfp-sfpplus14
/interface bridge vlan
add bridge=br0 tagged=sfp-sfpplus16 untagged=sfp-sfpplus14,br0 vlan-ids=4
add bridge=br0 tagged=sfp-sfpplus16 untagged=sfp-sfpplus14,br0 vlan-ids=1
add address=10.x.x.x/x interface=br0 network=10.x.x.x
Rules added, but for interface sfp14 in br0 PVID=1 and I have this situation: while pvid=1 - internet and adressing in network work, but not iptv. If I setup pvid=4 for sfp14 - multicast iptv now work, but internet and addressing - not work.
Is there a solution? Exist 2 vlan in uplink port and it needs to be forwarded to access ports (untagged mode, simulate unmanaged ethernet switch)
