I added “output=none” to avoid needing the “write” policy.
I tried adding “check-certificate=yes” but the request didn’t work then. Does RouterOS use a limited or outdated root certificate store?
Set up a scheduled task:
My question is – is this the optimal way to do this, or is there a neater, or more compact way? For example, is there a way to avoid having a script, but use the single command in the scheduler directly?
Use netwatch;
if you use url=“https://…” mode=https is unnecessary
you must install certs, if you want check https, for default no certs are installed.
Looks like on RouterOS v6 it can only do ICMP, and I first need to upgrade to v7.
On v7, looks like I can specify host by IP address and port, but it is not immediately obvious how I can specify an URL (with a domain name not an IP address, and with a path).
Thanks, that works indeed!
