sending TCP port out specific interface
Hi all
is it possible to route all outgoing traffic for port 25 over a specific gateway.
I have a 3 int mikrotik
2 gateways ether 1 and 3
all outbound mail must go to ether1 by default.
All web traffic - port 80 and 443 must go to ether3
I am running SRC-NAT masqurade on all ports
Ether 2 and 3 and internal addresses
Ether 1 is live ip addressing
Any ideas guys
Regards
Malcolm
Set up policy routing that routes such packets based upon a predetermined tag. Similar to Cisco’s route map command.
http://www.mikrotik.com/docs/ros/2.8/ip/route
Just using version 2.9 - do you have an example of how to do it.
The documentation doesn’t cover my exact problem
Thanks guys
Malcolm
