Hello Everyone,
Anyone can give me a script on how to separate date and time on the scheduler for the next run.
local user "26031970";
:local iValidUntil [/system scheduler get $user next-run];
put "$iValidUntil"
sample output: 2024-06-28 01:30:11
Hello Everyone,
put "$iValidUntil"
Do not use useless ; and put everytime the : on :local and :put
No matter if is only one examle. Bad habit stay on all little things.
:local test "2024-06-28 01:30:11"
:local findfrom -1 ; # -1 mean "from the start"
:local spaceposition [:find $test " " $findfrom] ; # find inside the string the character [SPACE] from the start
:local dstartposition 0 ; # the date start at the begin of the string
:local dendposition $spaceposition ; # the date end before the [SPACE] position
:local tstartposition ($spaceposition + 1) ; # the time start after [SPACE] position
:local tendposition [:len $test] ; # the time end at the last character of the string
:local d [:pick $test $dstartposition $dendposition] ; # pick the date
:local t [:pick $test $tstartposition $tendposition] ; # pick the time
:put "Date is >$d< and Time is >$t<"
Since the format have everytime the same lenght and position, can be simplified with static lenght and position:
:local d [:pick $test 0 10]
:local t [:pick $test 11 19]
:put ">$d<"
:put ">$t<"
Thank you very much for this script. You not only provided me the script, but also provided clear instructions on how to do it. I appreciate you providing me with information about this.
